Before/After Radiator & Thermostat Temps
Old Nov 4, 2012 | 09:22 AM
arod829's Avatar
Default Before/After Radiator & Thermostat Temps
Just wanted to provide my numbers here!
Replaced the radiator with a new one, put in a Motorad 439-180 thermostat, and flushed/refilled. As you'll see in my other post, as of now I am not sure of what my mix ratio is:
https://landroverforums.com/forum/di...l-issue-53993/
In any case, here is the before and after from my UltraGauge. These are all operating ranges with lowest to highest observed, and my truck is a 2003 Disco II with 70K on it. Waterpump is new also.
Before:
Idling: 215.6 to 221
City speeds: 212 to 217.4
Highway speeds: 210 to 215.6
After:
Idling: 199.4 to 206.6
City speeds: 199.4 to 203
Highway speeds: 195.8 to 201.4
I'd call that a success.
Old Nov 4, 2012 | 10:02 AM
If all else is OK, then your radiator is partially plugged up, replace it and you will drop even lower.
Old Nov 4, 2012 | 10:46 AM
arod829's Avatar
Hi Mike,
Radiator is brand new, water pump has only 3K miles on it, and both fans work perfect, new expansion tank cap. Motorad 439-180 thermostat. So...everything in the cooling system is pretty much new. The only thing that is probably not right is the coolant mix ratio.
Thanks!
Old Nov 4, 2012 | 10:47 AM
X2 on the clogs if radiato original. What will happen now is
(1) - if cooler time of year you will think everything is "peachy"; while the clog continues to grow by chemical reactions that take place 24/7, just at slower speeds while at cooler temps.
(2) - next summer your rad will be even more clogged, and heat problems will slide back up.
(3) - Pix of clogs. In a D2 rad, the spaces are so tight and the plastic so brittle on the side tanks that cleaning out by rod out is not practical. So a D2 radiator is a disposable item, like an air filter. On a D1 rad, which is copper and brass, they can unsolder a side tank, rod out the calcium buildup, and solder it back up, if caught in time.
(4) - monitoring with scanner or ultra gauge is a good thing. Maybe even a written log from time to time.
(5) - if done before clogs get much of a buildup various flush methods can prolong the swap of a radiator in any vehicle. But time, temperature, and corrosion eventually win. A radiator can be had for less than the price of parts for a head gasket on a D2.
if in question about % - a specific gravity tester (floating *****) will give you an idea. Or just flush with distilled water poured in from top and a hose off on the bottom, run engine a little to circulate coolant mix. Then re-fill and bleed. For a real test take some of the existing coolant and put in your freezer. Should stay liquid.
Attached Thumbnails Before/After Radiator & Thermostat Temps-dex-cool-2.jpg
Old Nov 4, 2012 | 10:50 AM
Missed the radiator replacement.
That being the case, you are still 5 or 6 degrees above what others have reported.
I will be replacing my Radiator and t/stat this month and will post what changes I get.
Old Nov 4, 2012 | 11:02 AM
arod829's Avatar
Thanks for the reply - I will repost with updated numbers once I adjust my coolant mix and make sure I have all air purged from the system.
Old Nov 4, 2012 | 11:12 AM
You might want to flush the system with distilled water before replacing the coolant.
Travelor
Feb 25, 2015 10:35 PM
acamato
Oct 19, 2013 10:07 AM
grandkodiak
Sep 30, 2013 06:01 PM
Dan7
May 21, 2013 09:00 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
