Engine tick
Old Oct 5, 2018 | 11:08 PM
  #21
redwhitekat's Avatar
Originally Posted by Discorama
I have the ticking at idle too, but only when hot. And it is intermittent, I do not notice a clear correlation to the temp. It goes away when increasing the revs slightly (900..1000) or after driving a few hundred miles, but the next day it is back. Recently I switched to a 82C thermostat, but that makes no difference. Since the frequency of the knocking sound is clearly at 6.25Hz (= 375rpm = camshaft rotation rpm at idle) I assume it is something around the camshaft/lifters. Wouldn't a slipping liner tapping at 12.5Hz (=750rpm = idle)?
To get a feeling for the frequencies you can use this tool:
how many mikes on your truck ? If it's been ticking for a while and the 180 stat doesn't help than drive it to the ground and buy a new engine. Unless you can figure out it's something else
Old Oct 5, 2018 | 11:30 PM
  #22
Discorama's Avatar
For miles check my signature. I hope it lasts another 30k miles, which is good for about 5 years. It got new head gaskets, valve cover gaskets and spark wires & plugs recently.
Old Oct 6, 2018 | 03:12 AM
  #23
99FLDISCOII's Avatar
Banned
Your temps are still way too high. I use distilled water with 2 bottles of purple ice + the 180 grey T stat and get 183-188 with spikes to 190+ in heat. And that is with a 10 year old crappy radiator. Once I put this brand new high volume 40mm 100% aluminum in with 14 fins inch2 it's going down to 175-180 for sure.
Old Oct 6, 2018 | 06:55 AM
  #24
Extinct's Avatar
check your oil pressure and report back, if it is low you could have either lifters ticking or even a rod knocking it would sound like a cylinder tic
Old Oct 6, 2018 | 10:50 AM
  #25
Dave03S's Avatar
What oil are you using? Often ticks can correlate with thin or synthetic oils.
Old Oct 6, 2018 | 11:14 AM
  #26
DiscoNickBK's Avatar
In what type of climate do you live? I don't think your setup would work if it's below freezing for 4 months a year, right?
Old Oct 6, 2018 | 11:25 AM
  #27
Dave03S's Avatar
The 180 thermostat is fine in cold climates.
Old Oct 6, 2018 | 11:33 AM
  #28
ohhhh geeezz your fine than
Old Oct 6, 2018 | 01:01 PM
  #29
Right, but a mix of just distilled water and purple coolant enhancer?
Old Oct 6, 2018 | 08:25 PM
  #30
Saturnine's Avatar
All i run is distilled water with a bottle of wetter water and thats it.
