Engine ticking
Engine ticking
Ok so I have been kind of avoiding this one as it will not stop me passing inspection lol.
But after swing this post
https://landroverforums.com/forum/di...s-47767/page3/
and I getting codes for bank 2 lambda and evaporator control issues I am begging to wonder if this is really my issue ?
so after buying it I new it had a tick after it warmed up. Also when going over the vehicle I noticed that the valve covers have been off and looks like head gasket has been done.
i had to do the oil pump
and the pcv mod now I am wondering ??
tick does seem to be on passenger side from what we can tell.
Was thinking it was a possible slip sleeve ?
As no noise when cold until warmed up.
still does it that way btw.
since the pcv mod it does sound lesser on the tick too ?
and definitely not a lifter noise as it doesn’t change with rpms like I have heard in the past with lifters
so wondering do I have a sai issue ?
thanks
thanks
@merebel sleeves as I understand it are more of a thud than a tick and not really that common, rockers, lifters bottom end are more likely.
but since pcv mod it does seem a lot less noticeable.
Tick when warmed up is likely slipped sleeve. I did have one that was oil pressure related (walked cam bearing - it got a new engine). Check your oil pressure, hot. Cylinders can be pinned to stop the ticking. Some say the tick causes hg damage, I have never seen it. Many have driven them with the tick for years.
