Engine ticking
Old Jun 3, 2020 | 04:48 PM
merebel's Avatar
Default Engine ticking
Ok so I have been kind of avoiding this one as it will not stop me passing inspection lol.
But after swing this post
https://landroverforums.com/forum/di...s-47767/page3/
and I getting codes for bank 2 lambda and evaporator control issues I am begging to wonder if this is really my issue ?
so after buying it I new it had a tick after it warmed up. Also when going over the vehicle I noticed that the valve covers have been off and looks like head gasket has been done.
i had to do the oil pump
and the pcv mod now I am wondering ??
tick does seem to be on passenger side from what we can tell.
Was thinking it was a possible slip sleeve ?
As no noise when cold until warmed up.
still does it that way btw.
since the pcv mod it does sound lesser on the tick too ?
and definitely not a lifter noise as it doesn’t change with rpms like I have heard in the past with lifters
so wondering do I have a sai issue ?
thanks
Old Jun 3, 2020 | 07:08 PM
Richard Gallant's Avatar
@merebel sleeves as I understand it are more of a thud than a tick and not really that common, rockers, lifters bottom end are more likely.
Old Jun 3, 2020 | 07:12 PM
merebel's Avatar
ok so then maybe not liners but it a tick and doesn’t change tempo with acceleration can get it to go away on hard acceleration and deceleration.
but since pcv mod it does seem a lot less noticeable.
Old Jun 3, 2020 | 07:21 PM
Extinct's Avatar
Tick when warmed up is likely slipped sleeve. I did have one that was oil pressure related (walked cam bearing - it got a new engine). Check your oil pressure, hot. Cylinders can be pinned to stop the ticking. Some say the tick causes hg damage, I have never seen it. Many have driven them with the tick for years.
Old Jun 3, 2020 | 08:20 PM
merebel's Avatar
And this is what I am getting on my codes
so it could point to the sai ?
Old Jun 4, 2020 | 05:16 AM
Extinct's Avatar
Get the code numbers from the scanner - an auto parts store can read them for you. Look them up on google and post the code number with the reason here. Then we can talk about root causes and components you need to replace.
Old Jun 4, 2020 | 07:28 AM
redwhitekat's Avatar
what temps are you running. If it’s over 210-220 they will tick.
Jason428sc
Apr 23, 2020 09:03 AM
Mr. Tick
Feb 22, 2018 11:37 AM
Sixpack577
Jul 18, 2017 08:20 AM
Tony Luna
Sep 9, 2015 01:32 PM
kevlor80
May 5, 2011 11:37 PM
