Engine to Transmission Bolts
Old Aug 4, 2019 | 03:12 PM
cvhyatt's Avatar
Default Engine to Transmission Bolts - Noob Mistake
Because I am a noob and a dumbass, I did not label which bolts went in which location.
Ok so now that that is out of the way, I have two issues:
  1. I have 12 bolts and I should have 14. What do the other two look like?
  2. What position does each bolt type go into?
Thanks in advance!!!
Old Aug 8, 2019 | 11:58 AM
cvhyatt's Avatar
No takers on the bolt question? Surely someone has this documented?!?
Old Aug 8, 2019 | 06:32 PM
05TurboS2K's Avatar
I just pulled my motor and labeled only SOME of the bolts. I figured I'd check an exploded diagram upon reinstall. Perhaps one can be found?
Old Aug 8, 2019 | 08:02 PM
Nosugar0carbs's Avatar
Why not place all the bolts in the holes(do not tighten) and see which bolts stick out more/less? Or a piece of rod and insert into bolt holes and measure which bolt hole is longer/shorter?
Old Aug 10, 2019 | 06:36 AM
cvhyatt's Avatar
Yeah that is where I am at today, I was hoping that I could find some documentation on these bolts but I have been unable to find anything. Today I will be bolting it up so I will document it and post my results.
Old Aug 10, 2019 | 03:51 PM
05TurboS2K's Avatar
Do what no carbs said, use any thin metal piece, even a chunk of metal coat hanger would give you the measurement. Draw a pretty picture on paper, write down (Long, medium, short) etc. I think there was just two lengths in the direction of Tranny towards Engine but I'd have to check.
Old Aug 11, 2019 | 06:11 PM
Also as a simple method, if one bolt hole has more area(from head clamping point to fastener threaded point) it will typically be a longer bolt. Not always but a lot more than so.
Old Aug 14, 2019 | 02:18 AM
JUKE179r's Avatar
@cvhyatt ... yes! please post it here for future reference to other V8 owners. Cheers mate!
Old Aug 15, 2019 | 02:42 AM
The Deputy's Avatar
You should have four of the shorter ones (in bottom row). Two go in below starter and the other two on drivers side...these four bolts thread into the trans bell-housing (head of bolt on engine side of assembly). Whereas all of the rest go into the engine block (bolt head on trans side of assembly).
Brian.
twin6
Feb 18, 2017 08:41 AM
Sprice
Aug 23, 2016 09:16 PM
Pik
Feb 28, 2013 08:19 PM
Torancis_LR
Jul 12, 2009 01:44 PM
