Engine woes and possible budget rebuild.
Old May 8, 2018 | 08:43 PM
Alex_M's Avatar
Alright, for those who are interested here is the copy/paste of everything that has been discussed as of yet.
Originally Posted by Alex_M
Back at it again. I had a couple hours so I tore back into Frankie. Good news and bad news. Good news; I found a nicked o-ring on the oil pickup tube. Hopefully that will cure some issues. Bad news; found lots of bearing material in the bottom of the pan. Even if this fixes the oil pressure, life of the engine has been greatly decreased. Hopefully it doesn't need new bearing immediately. Pplleeaasseeeee no rod knock. Bright side, the cam still looks good from beneath and no sign of movement from the new cam bearings.
I'll report back tomorrow when I get the pressure relief valve reinstalled and what-knot.
Originally Posted by Saturnine
Is Frankie the newly acquired D2 or is that the one you've had for a while?
The old guy. Named "Frankenstein's Monster" because of how cobbled together it really is. Been with me for... 5 years now, I think? We spat sometimes, but she'll stick around a long time.
The new dame doesn't have a name yet. The little lady wants to drive it a while before she settles on a name.
Today is a sad day. Confirmed that there is a deeper issue in the engine. I got the pressure relief reinstalled and filled her up with oil. I put in a fresh out filter to confirm that wasn't the issue as well. I pulled the engine and fuel relays and cranked her over for probably 30 seconds. Went back out, unthreaded the oil filter, nothing. It's not pulling out out if the pan for some reason. I can only suspect that the low oil pressure from the nicked o-ring caused the oil pump.p to run dry and wear the cover.
Autopsy will happen in a couple of weeks. I suspect she will end up sitting; not getting fixed. The girlfriend's will get the new cam, lifters, timing set, and the heads which were decked and had a valve job done 25k miles ago. Eventually I'll pull the engine and that's when I'll decide what it's fate is to become. Ls swap? Cummins swap? Leave it built as a trail/overlanding rig? Build it into a rwd prerunner? Who knows. That'll be a ways down the road.
Of course, there is a chance I can throw a used front cover on it and run with it, but with all the bearing material I found I'm wondering if I'd even want to go that route. Maybe I'll borrow the front cover off the girlfriend's and see if that works.
I dunno. I'll keep you guys updated one way or another.
Boooooo
Originally Posted by samroy92
Sad
Originally Posted by Jeff Blake
Bummer, Alex. You could pull off a quick and dirty rebuild?
Main bearings $30
Rod bearings $30
Connecting rod bolts $40
Piston rings $60 (optional)
Front cover? $300
Gaskets, seals $30
I think that's all off the top of my memory. No special tools or skill needed really other than some plastigage, feeler gauge, engine hoist + leveler. Heck you could even do the bearings with engine in situ, but it wouldn't be fun
Originally Posted by Davis31052
I have a front cover with new gears if you want to try it. I could only get about 6 lbs at idle with it, so I bought a new one from Lucky 8. Its yours if you'll pay the shipping.
Jeff, where you getting those bearing prices? I checked Turner and LR Direct; cheapest I could find anywhere was like $150 for the set. New rings would be cool. The bore looks like new, but she's only got like 110 lbs of compression across the board, warm. Not terrible, but I'd like better.
If I fix it she's definitely getting a new front cover. This one's seen better days even other than the oil pump issue. Also add to that list a $65 ball hone and a $75 head gasket set. Good opportunity to drop in those 4.0 pistons to bump the compression a bit, which would cost me bearings and rings to throw that extra 4.6 rotating assembly in the girl's 4.0. are the con rod pins press fit in the pistons on these trucks?
Also, I was under the impression the con rod bolts weren't stretch bolts, so it shouldn't need new ones. Right?
Davis, I appreciate the offer. She'll get a new front cover either way at this point, so no real need. What'd the cover from L8 run you? $300?
Con rod bolts are TTY, one time use.
Cheapest and best source is Turner:
https://www.turnerengineering.co.uk/...s-c102x3005626
Main bearings 25 pounds
Con rod bearings 20 pounds
Front cover genuine 245 pounds (does lucky8 sell the Britpart one? I don't know)
I underestimated piston rings.. those are actually 125 pounds
I preach turner all the time for engine parts!
Ideally you will want to inspect the crankshaft first to see if it needs turning, and order the appropriate sized bearings accordingly. Crank polish is like $40, turning it is around $100 (machinist)
Yes con rods and press fit in with a grudgeon pin. I didn't dissemble mine. Manual calls for a few special tools.
THIS^^^^^
The cheapest cover available through Lucky 8 is $403.00.
Ouch. Yeah, better off through Turner then, depending on shipping. I think it was $330 from Turner.
Also just double checked those bearing prices. I was wrong. Turner has main and rod bearings for like $55. I think Buick 300 bearings are the same size though. Be neat to check.
Could probably also use Buick 300 head gaskets. $10 ea for FelPro plus, what, $30 for bolts?
I'm gonna look more into Buick parts. I once had all the specs to see what crossed over from the 215 and the 300, but now I don't recall. I'll have to do some more research.
Or get the good Elring gaskets from Turner for $15/ea!
Main and rod bearings are both King (USA)
D*mn, new bolts it would be, then.
Rings must be what I'm remembering. Man, that's pricy. Would be good to find something that has the same bore size to get rings for. I'll do some research on that front.
If the crank is in poor shape I've got another. If they're both in poor shape.... I guess that would just have to add to the cost.
Getting pricy, gentlemen. We're in the ballpark of another $600-700.
I guess I'll start with robbing the front cover off the girls truck. It's gotta come off anyway. She's getting head gaskets and such anyway, so won't be any extra work on that front. Only cost one extra gasket to test.
Man, should've ordered parts right after Brexit when the pound plummeted so hard. Could've gotten all these parts for a pretty penny less.
I wonder what the compressed heights of the different head gaskets are? Wouldn't mind to get the thinnest I can find. More research to do...
Chevy 305 has a bore that's only 36 thousanths larger. Anyone know if you can over-bore these blocks by that much? Might run into issues there. Not sure.
Nooooow we're getting into pricy machine work.
36 thou is a lot. Oversize (grade B) pistons were only 2 thou oversize. I wouldn't want to make those water jacket walls any thinner.
Yeah, that's what I figured. And no way I'm resleeving the block. If I were to go that far I'm just getting a Turner block.
Lots of good info here:
Buick 215 Rover 3.5 Land Rover 4.0 and 4.6 differences
I haven't gotten to really dig into it deep yet, but I will.
Originally Posted by Sixpack577
Lol
The cylinder sleeves can't be much more than .036"
if they're that thick.
I wonder what was so special about the Buick 300 block? The bore in those was 50 thou larger. I don't think they were even cross bolted like our Bosch engines are. I'm not positive on that though.
I'm going 0.20 over. we will see what happens.
Cast iron block.
A different block.
The 4.0/4.6 was "based" on that design.
It's hard, if not impossible to get a sleeve wall thickness measurement of the sleeve while it's in the block.
However, they are thin.
.020" bigger is technically a -.010" thinner wall, about 2 1/2 sheets of paper thick, so not much.
But, it is substantial.
If they are boring them that much, I hope it has been done several times before...and not caused heating issues.
Aluminum disapates heat much faster than steel,
so the heat the block absorbs goes away faster than in an iron block.
Ah, ok. Man, what I wouldn't give for an iron block in the Disco.
lol, yeah, a little heavier, but apparently more dependable than the poorly cast aluminum ones.
Old May 8, 2018 | 08:52 PM
Jeff Blake's Avatar
Don't forget new dowty washers for the cross bolts
Cruciform seals for rear main bearing cap as well
I'd never even worked on a car before my LR, and within a few months I rebuilt the engine. It's pretty easy, just follow the manual. Really helps to actually check all the measurements (it's very tempting to say, well, **** it, and do it live) with micrometers, dial bore gauge, feeler gauge, etc to give you confidence in the work done. For the crank run-out, you can stick it in the block as a substitute for vee-blocks and use the DTI appropriately.
Old May 8, 2018 | 09:48 PM
Alex_M's Avatar
10 of those washers, yeah? Looks like they don't have to be application specific. I'll pick some up at the auto parts store in bulk.
and 2 Cruciform seals?
Right now, here's what I'm looking at. I'll do more price comparison shortly.
From Rock Auto: $27 for Exhaust gaskets, head gaskets, water pump gasket.
From Turner: $177 for bearings, bolts, valley pan, cruciform seals
plus: $76 for shipping across the lake
From eBay: $62 for rings
Plus a front cover on top of that. $270 if the one on eBay doesn't sell before I can get it. $330 if it does.
Grand total: $672. Ouch. The search continues.
Oh, I forgot the $60 ball hone.
Old May 8, 2018 | 10:46 PM
Alex_M's Avatar
Ok, update. Cost cutting has worked. It looks like it actually pays me not to get anything from Turner, unfortunately.
From Lucky 8: $76 for Main bearings, Con rod bearings, front cover gasket, and cruciform seals.
From Rock Auto: $78 for Exhaust, head, water pump gaskets, valley pan, and head bolts
And from eBay: $201 for ball hone, piston rings, and con rod bolts.
Again, front cover is up in the air. I'll add $270 for the one on eBay.
That brings us to $625. If you include the ball hone above, that's $100 less.
Old May 8, 2018 | 11:38 PM
No Doubt's Avatar
Talking
That's one cheap rebuild, congrats!
Old May 9, 2018 | 06:55 AM
Saturnine's Avatar
Nice work!
Old May 9, 2018 | 08:16 AM
Sixpack577's Avatar
I would consider the Bearmach cruciform seals instead of the Allmakes. $12 shipped on ebay
They are made differently, and after holding each, the Allmakes look like junk that will leak.
Attached Thumbnails Engine woes and possible budget rebuild.-20180411_204131.jpg
Old May 9, 2018 | 02:35 PM
Alex_M's Avatar
That's good info. I'll follow your recommendation.
Thanks guys!
Old May 9, 2018 | 09:47 PM
Alex_M's Avatar
I've done some further thinking and talking. For now I think my best option is to put the Disco on the sidelines. I'll go back to driving the Silverado and save up to fix it's front end pop and lifter tick. It's better suited for what I do anyway, for the time being.
It bums me out, but I think it'll be for the best. The little lady will get my new cam and lifters instead of factory replacement parts and all will be well with the world, for now. Hopefully in a years time or so I will be able to drop the dough and get her back on the road how I really want to; with 35s, a manual transmission, 4.56 gears, and... Maybe an engine swap. The list goes on. We'll see where it goes.
Thanks guys for all your help! For anyone else needing to do a budget rebuild; here's a good blue print. One little addition; lucky 8 has 4.0/4.6 piston rings for $75/set. That's only $15 more and they're sure to fit.
Old May 9, 2018 | 09:51 PM
Saturnine's Avatar
A year?! That is just cruel
