everyone with more than 150K on your original LR head gaskets
Old 10-15-2014, 10:20 AM
drowssap's Avatar
Default everyone with more than 150K on your original LR head gaskets
please sign in.
Old 10-15-2014, 10:35 AM
RicketyTick's Avatar
Originally Posted by drowssap
please sign in.
Well I probably shouldn't sign in but, mine went to 141,465... no warning, no prior leaking, wasn't running hot, no nothing and never ran hot at least in the 70K that I'd had it. Started it up and it was misfiring bad and gasket just decided it was time between water jacket and #7 to the inside. Not the kind of blown head gasket you can drive with and add water. Luckily, I was just at a store only 1-1/2 miles from home. First thing in the morning, ran fine on the way to the store, went inside, came out, started it and it happened right then and there. No prior misfires or any signs it was coming. I guess I made it more miles than the norm!
Anyway, I just wanted to communicate that they don't always give a warning. Not normally how it happens I know!
Old 10-15-2014, 10:42 AM
ZGPhoto's Avatar
I think it was 152k when I did mine
Old 10-15-2014, 12:28 PM
TRIARII's Avatar
I dont know for certain weather my original head gaskets were changed but I assume they are factory. Right now Im at 145,xxx and counting. By the time I head to Ak ill be at 150+ miles.
Old 10-15-2014, 12:53 PM
dusty1's Avatar
can't be 100 %, but bought a "parts truck" from 2nd owner with 155k. he said he had the truck since 80kish and hg was, now, blown and it had other issues. wasn't running..
turned out it was not hg leak. just cracked manifold and tbh leak.
again not 100% if original owner had hg done, prior to 80k. I sold the truck with 160k and still going.
so I guess that's pointless, since I have no clue of the first 80. sorry.
Old 10-15-2014, 01:19 PM
Yea same here. I have no way to know for sure if they were original on mine either. They had elring gaskets but that don't mean much. Coulda been changed a week before I bought it at 70K for all I know.
Old 10-15-2014, 01:20 PM
disc0man's Avatar
Just changed mine at 150,080 miles. No catastrophic failure or anything, just finally decided to change them after I was losing a small amount of coolant and the occasional misfire. Running like a top now!
Old 10-15-2014, 01:29 PM
roar huge's Avatar
I'm at 140k, and mine are toast. Looks like two external leaks, one on each side. Looking for estimates on replacing them in the Seattle area. Gordn at Lamorna quoted me $2600, which I'm pretty sure is more than the entire truck is worth....
now I understand why people here list repairs completed in the signature field vs. mods....
Old 10-15-2014, 01:32 PM
Dave03S's Avatar
I don't know about your vehicles but the sides of my heads were noticeably aged and coated with enough grime to look just like the rest of the block.
Now that it has been 25k since my HG job the sides of the heads around the spark plugs still look shiny compared to the block. That might be one way to tell... if the person changing them did indeed get the heads cleaned and or machined in the process. Also when my heads were done the shop did not replace the fabric wrap around the SAI pipes.
Even as the truck ages it should still be evident if the heads have been cleaned and the block not.
Old 10-15-2014, 01:35 PM
MetalMarine's Avatar
im at 178k and they are leaking. its been leaking for 12k miles. bought the truck when it had 160k on it. couldn't tell you if they are the originals. but they are bad and need to be replaced.
just need to scrape up the 200$ to buy the rebuild kit and do it before I lose the engine.
Quick Reply: everyone with more than 150K on your original LR head gaskets
