Exhaust joint flanges
Old May 24, 2022 | 04:07 PM
cappedup's Avatar
Default Exhaust joint flanges
One of my middle box hangers rusted through, leading to an annoying rattle where the rear box now hits something. The second middle box hanger isn’t far behind.
I’d like to swap the middle and rear sections but the join/flanges where the middle joins the front Y is badly corroded.
The pipes themselves look ok and I’d like to avoid messing with the front section. Cats, O2s etc.
Will a new middle section be able to join to an old front in this instance?
Or am I left with the welding option if I want to keep the front while swapping the middle?
Old May 24, 2022 | 05:52 PM
Harvlr's Avatar
It does look pretty bad in the photo. If it was me I’d try taking it apart and see how bad that forward flange really is. You might be able to use it. You probably don’t have anything to lose in trying.
Old May 24, 2022 | 10:46 PM
Dervish's Avatar
Nothing to worry yet, still plenty of metal there, all I got is the gasket. Hangers are also almost gone.
Going to get all stainless before winter.
http://i.imgur.com/1iY1BDK.jpg
I think my exhaust is the original from 2002, oh and it's a TD5.
Old May 25, 2022 | 08:21 AM
cappedup's Avatar
It would need drilling to take apart. Bolts are now rusted nubs.
If the flange IS toast, does that rule out using the whole front section? That would drastically alter my job.
Is there any kind of bolt together flange, for this case, where the pipe is ok, but the flange is done?
Old May 25, 2022 | 01:43 PM
Harvlr's Avatar
Drilling or grinding for sure. Worst case scenario would be you need a muffler shop to weld the intermediate pipe to the front pipe. I’m pretty sure you don’t need to replace the front section (unless the cats are plugged).
Old Jun 17, 2022 | 09:03 PM
cappedup's Avatar
Anyone tried this full aftermarket system from Rimmers? Cheap enough.
https://rimmerbros.com/Item--i-RD1197MSP
I can imagine not all O2s are made equal. Any recommendations?
Edit. Just realised that might not be in the US. Guess I’ll find out Monday.
Old Jul 11, 2022 | 07:55 PM
cappedup's Avatar
Stripped the joint around the Y pipe and the pipe joint flange was in great condition.
I cut off what was left of the existing Y pipe flange and fitted the back two sections using a split collar.
Back to sounding quiet, bit more power back.
hipkiss
Sep 11, 2021 08:07 AM
WaltNYC
Jun 3, 2021 01:02 PM
Jason_B
Nov 4, 2018 02:17 PM
breedspeed
Jan 13, 2016 08:44 AM
The Didge
Apr 3, 2007 11:57 AM
