Exhaust Leak
Old Aug 7, 2009 | 12:34 PM
NM-DiscoDuck's Avatar
Default Exhaust Leak
As many of you know, I've been trying to chase down an 1177 code and fix the problem for some time, as well as a hot starting problem.
I have discovered an exhaust leak on the driver's side (USA) behind the wheel (I wondered why the motor seemed loud).
When I fix this problem, does anyone think that these issues will go away and I can finally get my Disco I emission tested? I'm at wit's end.
Old Aug 7, 2009 | 01:37 PM
(sigh)
Now that it's daylight, I went under the Disco to take a good look at this leak. Seems the PO had this problem before and tried to fix the issue by putting JB Weld all over the flange...and now it's flaking off. Problem is, the JB Weld is smeared all over the nuts holding the flange together. I might be able to chip this stuff away with a screwdriver, but I don't know.
That being said.... Is this the right part??
http://www.roverparts.com/Parts/ETC4524.cfm?bc=ab
Old Aug 7, 2009 | 01:59 PM
malmberg's Avatar
Yes that is the correcrt part but I would also buy some new studs and nuts while you are at it. Good luck getting it off. You also should check the other side to see if it needs replaced.
Old Aug 7, 2009 | 02:40 PM
Thanks for wishing me luck in getting that thing apart. I'm going to need it. The other side is quiet and no "puffs" coming out of the flange at all.
WaltNYC
Jul 27, 2015 02:24 PM
twaszak
Jul 15, 2012 07:21 PM
Street Wolf
Jun 24, 2011 01:59 AM
rgrizzard
Mar 6, 2008 10:16 AM
breal372002
Jun 26, 2007 12:14 PM
