Exhaust leak detection?
Agreed with above, however if prevented from doing that sort of treatment, you can also use an infrared thermometer to "shoot" suspected joints, a leak normally makes a smudge, and on mine the temp at the leak spot was over 400F even though truck was just started and rest of system had not warmed up yet. Another shade tree way is to shove the output hose from a shop vac up the tail pipe, putting slight air pressure in the system, truck not running. Blow smoke from a quality cigar and look for air currents. Once found, enjoy the rest of the cigar. Note: a cheap cigar will work just as well.
Don't try SeaFoam inside the garage....
Dweller in the Desert
08-19-2015 06:21 PM
