Exhaust leak detection?
Old Jun 29, 2012 | 10:23 AM
0304Disco's Avatar
Default Exhaust leak detection?
Does anyone know if there is a digital tool/meter for finding exhaust leaks? I have a leak and this would help greatly in find it.
Old Jun 29, 2012 | 10:41 AM
drowssap's Avatar
cheapest way do a seafoam treatment and partly block the exhaust with a rag, if there is a leak you should be able to see it then.
JMHO
Old Jun 29, 2012 | 12:37 PM
bostongrun's Avatar
I agree Seafoam is the best. Just pull a vacume line and pour 1/3 to 1/2 bottle of Seafoam into a cup or similar vessel and let it suck in; I guarantee you will find the leak.
Old Jun 29, 2012 | 12:45 PM
Agreed with above, however if prevented from doing that sort of treatment, you can also use an infrared thermometer to "shoot" suspected joints, a leak normally makes a smudge, and on mine the temp at the leak spot was over 400F even though truck was just started and rest of system had not warmed up yet. Another shade tree way is to shove the output hose from a shop vac up the tail pipe, putting slight air pressure in the system, truck not running. Blow smoke from a quality cigar and look for air currents. Once found, enjoy the rest of the cigar. Note: a cheap cigar will work just as well.
Don't try SeaFoam inside the garage....
Old Sep 24, 2012 | 04:27 AM
carlforbes's Avatar
Opting a leak detection company for exhausting leaks could be a wise decision if nothing is working out.
Old Sep 24, 2012 | 07:36 AM
antichrist's Avatar
Another way to find leaks, that's 100% free, is fold up a rag and use it in the palm of your hand to block off the exhaust. Then have someone listen to where the exhaust is escaping in the system.
Old Sep 24, 2012 | 07:39 AM
drowssap's Avatar
the original post is 3-months old
Old Oct 22, 2012 | 09:43 AM
daza87's Avatar
JMHO
Thanks for that, I'll give that a try as I've got a leak.
Dweller in the Desert
Aug 19, 2015 06:21 PM
WaltNYC
Jul 27, 2015 02:24 PM
bballjames
Feb 22, 2013 08:49 PM
cobbcj7
Jan 3, 2012 07:47 AM
mr_boondoggle
Jan 19, 2009 02:15 PM
