Exhaust Manifold Bolts
Old Mar 4, 2023 | 03:30 PM
alexscott's Avatar
Default bolt threads
Originally Posted by mollusc
Seems odd that it would be a non-metric thread. I know there are some places on the D2 where there are metric bolts that don't have the correct size head for the diameter of the shank, but I'm pretty sure all the threads I've come across in/around the engine have been metric. (Not that I've checked them all, though.)
In simple terms this is my understanding. The threads into the alloy block are all UNC(fine threads are no good in an alloy block). Threads into steel are all UNF. Then circa 1978 metrification (those who had a 109 v8 might relate to this) started so any new parts were often metric I think it might even be explained in the workshop manual for the 109v8. Obviously the blocks could have been metricated (with course metric threads) but that would be confusing right and really mess up some blocks? So this is why you find that parts on the later bodies are often metric and parts on the engine are imperial. It's useful to know this.
Old Aug 21, 2024 | 08:10 AM
CharminULTRA's Avatar
I can’t find this anywhere, what LENGTH? Someone previously said 3/8-16 but left out the length spec.
Posting here as it’s the best thread I’ve found online about these bolts
Old Aug 21, 2024 | 08:30 AM
sqlbullet's Avatar
Not sure. Not to be rude, but rather than asking on the internet, I would pull an adjacent one and measure it. Or if you are concerned about un-threading another one, stick a skewer down the hole and measure the depth, and go shorter than that by about 1/8". Or if the whole manifold is off and all of them are broken/gone, check the hole depth, flange thickness and spacer thickness to find the length.
NVRover
May 12, 2022 09:08 PM
Dean
Jul 17, 2013 08:45 AM
Disco Alan
May 17, 2011 03:54 PM
surfoblb
Feb 8, 2011 06:01 PM
97discoI
Aug 3, 2007 01:25 PM
