Exhaust Stud/Bolt/Gasket Question
Old Nov 8, 2017 | 09:14 AM
CollieRover's Avatar
Default Exhaust Stud/Bolt/Gasket Question
While doing my starter I noticed that one of the studs and bolts had disappeared. Can I just replace the stud and bolt or should I do a new gasket, it is less than a year old.
Old Nov 8, 2017 | 09:42 AM
OffroadFrance's Avatar
If it were me (god help you) I would replace the whole or the affected part of the exhaust gasket. The old one will be flatted or misshapen. Check the manifold to see whether it's distorted (curved) and if so, have it skimmed/milled flat.
Old Nov 8, 2017 | 08:22 PM
LR03NJ's Avatar
If you have to replace the gasket, make sure to marinate the stud in PB Blaster. It will make your removal much easier. Impact wrench with a long extension did me good. Exhaust parts in front is easy as long as you PB blaster it for a while. Forget about the rear, you need to cut the bolts.
Old Nov 8, 2017 | 09:41 PM
Friday Night Disco's Avatar
Check out my Tricky Dick tread on the challenges I ran into
http://<a href="https://landroverfor...ust-84027/</a>
Old Nov 9, 2017 | 08:49 AM
Link would not work, but I am going to try to find it.
Old Nov 9, 2017 | 09:42 AM
try this link
https://landroverforums.com/forum/di...exhaust-84027/
Old Nov 13, 2017 | 12:38 PM
Since the gasket was done very recently I put in a stud, which luckily threaded, and the locking nut. Screwed it in from above, then started the nut, got underneath and tightened it up with an impact gun, and a few extensions with a swivel. It's not to be torqued on too hard, 24 ft/lbs if memory served so I did not go nuts.
I'll have to listen for the tick, and inspect it here and there, I have not been hearing any tick, so hopefully this will take care of it.
DiscoBuckeye
Mar 28, 2016 09:24 PM
lilherc
Apr 25, 2013 11:22 PM
dparham
Dec 12, 2012 02:57 PM
logicmike44
Aug 29, 2012 12:36 PM
Chrisinhouston
Dec 30, 2009 06:40 AM
