Expansion Tank Recommendations for an '04
Old Sep 24, 2012 | 02:04 PM
lrjon's Avatar
Default Expansion Tank Recommendations for an '04
I have a small leak in my expansion tank and need to replace it. The OEM part is PCF101410 and goes for anywhere from $100 to $300. I have seen non-OEM tanks for considerably less money. I have also heard that any DII expansion tank should work (the PCF101410 is specified for only 2003-2004).
Any recommendations on a cheaper replacement? Is it really true that any DII expansion tank will work for my 2004 Disco?
Old Sep 24, 2012 | 02:15 PM
jafir's Avatar
The 99-02 tank will work. I've seen an aftermarket for $39 on rock auto, but the one person I've seem comment on it said it wouldn't last.... not sure.
I think I'd give it a try anyway.
Old Sep 28, 2012 | 11:27 AM
lrjon's Avatar
jafir -- thanks for the recommendation. I bought the rockauto.com URO ESR2935 tank for a 2002 Disco and installed it last night. It fits perfectly and seems to be of good quality.
So the case seems to be that a PCF101410 is the same as a ESR2935 tank.
Old Sep 28, 2012 | 11:48 AM
If you didn't do it, replace the cap and t/stat also, using the 180 soft spring t/stat for better cooling.
aguison
Nov 16, 2012 09:29 AM
ulviking44
Freelander
Jan 6, 2009 01:43 PM
samue23
Feb 25, 2008 07:43 PM
twalter87
Sep 9, 2007 08:47 AM
