Extended ABS Lines
Old Apr 19, 2013 | 12:06 PM
ZGPhoto's Avatar
Default Extended ABS Lines
Has anyone bought/run these? I'm at about 3+" of lift, just got some slickrock front sway disconnects and don't want to rip the wires out. Let me know!
Cheers,
Zack
Old Apr 19, 2013 | 12:53 PM
MuddMouth's Avatar
Id say get, the 120 bux is worth the peace of mind.
Old Apr 19, 2013 | 01:34 PM
ZGPhoto's Avatar
Yeah it's not the money I'm concerned about. I was reading a few other forums and there was a guy with a 5.5" lift running no sway bars and original ABS lines. I think DiscoMike chimed in that you could just unclip all the lines for more travel.
Old Apr 19, 2013 | 01:40 PM
MuddMouth's Avatar
You can, when you were fitting your springs I would imagine you unclipped everything right? I did and was surprised at how much extra there was. The only problem I saw with it was a way to secure them... zip ties maybe but looks like poo... I got ss lines and extensions on order ...
Edit: those sway bar disconnects are the cats *** too I ordered some of those about 2 seconds after I saw your post... thanks.
Old Apr 19, 2013 | 01:51 PM
ZGPhoto's Avatar
Yeah I got the SS brake line extensions, I'll check on the ABS lines when I install the disconnects.
And yes, they are definitely the cat's ***, the build quality is definitely all there.
ebg18t
Aug 20, 2013 05:16 AM
grandkodiak
Nov 10, 2011 01:45 PM
bosshogt
Sep 9, 2010 07:31 PM
raid13
Jan 16, 2009 03:49 PM
markroll
Mar 19, 2008 10:04 PM
