Extended brake lines
Old Oct 22, 2020 | 08:36 PM
zski128's Avatar
Default Extended brake lines
I have a 3 inch lift and my brake lines are pretty taught. I have 2”+ shocks installed as well. The 2” extended lines that AB and L8 sells don’t seem like they will be long enough. Any suggestions on a place to get 3”+ lines? I will have extended sway bar links with disconnects to I want to only purchase once. I have used google to search this site but couldn’t find my answer.
Old Oct 23, 2020 | 09:24 AM
whowa004's Avatar
I went with the Britpart +6" lines and will be adding them to my other disco as well (that one is running +2 or +3" lines and I don't think it's enough). Both rigs are 3+" of lift and no sway bars. The Britpart lines are no more expensive than the other stainless lines.
Old Oct 23, 2020 | 10:36 AM
zski128's Avatar
Thank you for the info. How are the Britpart lines? I am usually leery of using parts from them.
Old Oct 23, 2020 | 11:50 AM
whowa004's Avatar
Happy so far, not a whole lot to brake lines but I did not have any concerns putting them in nor have any fitment issues.
Old Oct 23, 2020 | 11:55 AM
Best4x4's Avatar
Don't forget to extend your ABS Sensor wires as well
Old Oct 23, 2020 | 12:18 PM
whowa004's Avatar
It helps to have those hang loose but I routinely rip out my rears as I haven't extended mine yet. It's on the list....lol
Old Oct 23, 2020 | 12:26 PM
zski128's Avatar
This is on my list as well. Looks like the fronts have plenty of slack if needed. I have new front bearings coming so my plan is to use the abs sensors from the old front hubs in the rear.
Old Oct 23, 2020 | 12:34 PM
Best4x4's Avatar
Yep just slap the fronts in the rear!
dealbergaria11
Feb 27, 2020 03:13 PM
RSPTex
Jul 16, 2014 08:33 AM
wynhd
May 17, 2014 04:53 AM
BayerischeDisco
May 2, 2014 12:50 PM
ZB-30
Jul 10, 2012 03:22 PM
