Extra Gauges!
Old Apr 12, 2019 | 09:33 AM
markdeg's Avatar
Default Extra Gauges!
So I was thinking of adding a few extra gauges on my TD5. Since I have remapped the engine I was thinking of adding boost and egt gauges, but what else would be beneficial, ideally spot problems before they become disasters? I was thinking Transfer case and transmission temperatures (mine is a manual)? What else? oil temperature/pressure?
Old Apr 12, 2019 | 06:41 PM
Extinct's Avatar
Coolant temp and oil pressure should be #1 and 2.
Old Apr 12, 2019 | 08:19 PM
Red5's Avatar
Since it's a diesel, EGT and Boost. Then
Coolant temp
Oil Press
Voltage
If you have a manual, trans temp is probably not an issue. But wouldn't hurt to know either.
Old Apr 13, 2019 | 03:17 AM
DavidOHendo's Avatar
Banned
What's a normal oil pressure reading on the Nanocom ?
Old Apr 15, 2019 | 02:04 AM
markdeg's Avatar
isnt the coolant temp already on the dash?
Old Apr 15, 2019 | 03:17 AM
shanechevelle's Avatar
I think he means coolant temp by degrees since the rover temp gauge is...poor at best.
Old Apr 15, 2019 | 06:31 AM
markdeg's Avatar
ok, but (i think) it gives a reliable indication? I mean as long as it is in the middle I do not care what the actual temperature is? or am I wrong? Or maybe it is not getting the reading from the best location?
Old Apr 15, 2019 | 07:26 AM
OverRover's Avatar
The coolant temp gauge in a LR is just a glorified idiot light and NOT TO BE RELIED ON!
A proper quality add-on gauge like you are thinking is the way to go.
Old Apr 15, 2019 | 07:33 AM
Red5's Avatar
I did mean a gauge that shows the actual coolant temp. I'm not familiar with the TD5 version, but with the V8, the needle doesn't start moving past half way until you get to 235 or something like that. Most will tell you that is way to warm for these blocks. I suspect that the diesel is maybe more forgiving temp wise, but still good to know the actual number.
Davis31052
Jul 9, 2018 05:33 PM
Jeff Blake
Jul 25, 2016 12:22 PM
mule2ears
Nov 16, 2015 07:43 AM
willo
Sep 13, 2015 10:37 AM
lipadj46
Oct 17, 2010 06:34 PM
