Factory Radio AUX
Old Jul 22, 2022 | 07:45 PM
m1943's Avatar
Default Factory Radio AUX
Hello. I have a factory radio, that has a casette player (in 2003!!) but no CD slot. It does have a "CD" button, which is probably supposed to activate the 6-disk CD changer that this particular car has never had. My Disco is pretty much a basic model, no sunroofs, no suede in the doors, no premium sound, and no CD changer, among other things. Question: does that factory radio have some kind of an AUX jack in the back of it? What is the easiest way to connect a smartphone or a Blue Tooth receiver to the original radio? Is there an easy "plug and play" option there? Thanks
Old Jul 22, 2022 | 08:14 PM
Sandman614's Avatar
Lookup GROM aux audio adapter, there are other brands that I can't think of right off. There should be one that plugs into the disc changer plug
Old Jul 22, 2022 | 08:56 PM
mln01's Avatar
I concur with Sandman. I've had a GROM unit in my '99 DII for around 10 years and it's been great. It plugs into the back of the radio in the place that was designed for the CD changer. It's a little pricey at $175.99 but it's plug and play and it works great. Link below.
https://gromaudio.com/store/bt3_adap...interface.html
Old Aug 3, 2022 | 09:59 AM
m1943's Avatar
Default Thanks
Thanks! What about the couple of connectors found in the left "vent space" in the cargo area? If they are CD changer wires, could an adapter be used to install something there? Anybody tried?
Old Aug 3, 2022 | 11:00 AM
mollusc's Avatar
They're not CD changer wires. The CD carousel is under the passenger seat.
Old Aug 3, 2022 | 11:41 AM
gecko951's Avatar
You can get this unit from Grom which just adds the 3.5mm aux adapter: https://gromaudio.com/store/aux1_ada...tereo-kit.html
Another less expensive option is to purchase a car audio cassette tape adapter to aux adapter or apparently you can get them with bluetooth now?!?!?
https://www.ebay.com/itm/31323416345...wAAOSwbyVhRa~i
Old Aug 3, 2022 | 02:37 PM
m1943's Avatar
Does any one know what these are? There is two connectors, one is small, the other mid-size. They are much smaller than the stock towing wiring harness connector that is supposed to be located under/behind the right side tail light.
Old Aug 3, 2022 | 06:04 PM
mollusc's Avatar
Possibly for the rear A/C, or maybe the headphone socket that's a little forward of that area for the high-end audio system. Different models have different accessories.
You'll need to provide better information than "small" and "mid-size" connectors if you really want to track them down. Wire colours, number of pins, connector shape, etc. Photos help a lot.
rikkd
May 5, 2021 10:39 AM
wcr4x4
Dec 5, 2013 11:24 AM
dannydesch
Apr 25, 2009 08:53 PM
frogeye1000
Freelander
Jan 20, 2009 05:33 PM
russ00001
Apr 20, 2006 09:47 AM
