Factory Radio Specs
Old Jan 3, 2018 | 02:29 PM
Davis31052's Avatar
This info was copied starting at pg. 86-6-11
Old Jan 3, 2018 | 02:35 PM
robert.juric's Avatar
Ahh thanks again!
Old Aug 26, 2024 | 02:42 PM
Crusinvans&LRD2'S56's Avatar
Default Speakers
Originally Posted by robert.juric
I've got to replace the speakers in my '01 D2. I'd like to get a pair that can adequately handle the factory head unit's power output. Does anyone know what that is though?
While I'm at it does anyone have any speaker brand recommendations? It's been high school since I looked at car audio.
Enclosed Bose speakers just in case mud gets flung into the vehicle
Old Aug 29, 2024 | 06:50 AM
nick wells's Avatar
Default How did you install the amp
what did you do to install a new amp for it because I didn’t think it came with one stock. Correct me if I’m wrong but isn’t the amp apart of the radio in the car
Old Aug 29, 2024 | 08:46 AM
mollusc's Avatar
No. The amp is under the driver's seat.
Old Aug 29, 2024 | 09:56 AM
Externet's Avatar
Somewhere I learned there is two types of radios.
The 'high end' type is the one that outputs not-speaker-levels ('line levels') ---> towards a necessary separate power amplifier under the driver's seat. Seen the guts of that radio has provisions for implementing an audio amplifier integrated circuit in the back of its mainboard, that way becomes the 'low end head' that would feed speakers directly with no amplifier under seat.
The amplifier is not a part of the radio on the 'high end type' The amplifier is apart from the 'high end type'
The best replacement speakers are healthy originals obtained at a boneyard. They are matched-equalized to the vehicle room acoustics. Factory did not install anything random as in a seventies car.
Old Aug 30, 2024 | 07:59 AM
mollusc's Avatar
Interesting. All three of mine have had amps even though only one was the "high line" system.
Old Aug 30, 2024 | 10:33 PM
Discorama's Avatar
The schematics for the base/mid line show speakers connected directly to the head unit. Only the high line has the power amp under the driver's seat. It's possible that the base / mid line audio configuration with the external power amplifier was a production optimization. Both can share the same wiring harness.
Old Aug 30, 2024 | 10:41 PM
Discorama's Avatar
Replacement speakers should not sound worse if they match the parameters like impedance, frequency range, SPL (sound pressure level) aso. of the original speakers. Original speakers (given they are still in good condition) can be measured to find the best replacement, but that's beyond the scope of most DIY wrenchers here.
KS_Discovery04
Jan 13, 2023 12:20 PM
Joemamma1954
May 10, 2015 11:04 PM
95_rover
Audio/Visual Electronics
Nov 10, 2012 11:56 AM
dcreekmore44
Feb 17, 2009 05:04 PM
bklahl
Aug 9, 2006 07:36 PM
