Fan clutch tool
Old Apr 15, 2018 | 03:17 PM
zev666's Avatar
Default Fan clutch tool
Having trouble getting fan off a 2003 discovery 2. Have the 36mm wrench and wedging along screwdriver in to hold the pulley. Will not budge. Hit it with a Mallot. Used liquid wrench. Just ordered the 60$ fan clutch tool. Hope this works. Any ideas , tricks????
thanks
Old Apr 15, 2018 | 03:27 PM
LR03NJ's Avatar
Make sure the belt still on. Then hit hard to the left with mallet.
Old Apr 15, 2018 | 03:33 PM
OverRover's Avatar
I like this fan clutch tool ... works like a champ!
It's a Schley 61600 > https://www.jbtoolsales.com/schley-p...SABEgLUM_D_BwE
I hope this is a Captain Obvious statement, but you are turning the wrench in the correct direction... to the Passenger Side/LEFT (NAS LR)?
Old Apr 15, 2018 | 03:41 PM
zev666's Avatar
Ha, yes. Ordered that tool today. Hitting to the left , did not budge. I have seen videos where guys just hit it with the mallet. No luck for mine. Thanks guys, can't do my real work till I get this off
Old Apr 15, 2018 | 04:00 PM
OverRover's Avatar
If you need to get things done before the Schley tool comes in you could rent a similar fan clutch tool from AutoZone or Advance.
But if you wait for the Schley you will not be disappointed, that thing works every time.
Old Apr 15, 2018 | 05:58 PM
LR03NJ's Avatar
I dont think there is a special trick with the removal. I just thought at the moment if you could loosen the pulley tensioner and wedge about a half inch to an inch wood in one of the pulleys then release the tensioner. You might be able to get the belt more tight. Then hit the tool really hard towards your left no holding back. Good luck
Old Apr 15, 2018 | 07:25 PM
Jwehking's Avatar
I’ve used a vice grip on the lip and butt it up against something and hit the wrench with a mallet
Old Apr 15, 2018 | 09:02 PM
Best4x4's Avatar
The trick isn't hitting it to the left *(it will just try to spin the pulley more vs loosen the fan clutch), but actually downward. Place the adjustable/36MM Fan Clutch tool at 12oclock, then using a sledge or a dead blow hammer hit it with a downward hit at a very slight angle to the left. Normally 2-3 good taps like that and it will bust free.
Old Apr 15, 2018 | 10:23 PM
stillruns's Avatar
D1 but You get the point:
Old Apr 15, 2018 | 10:44 PM
razorkill12's Avatar
I just used A long air chisel on my air hammer and it came off in 3 seconds...but if you have no air tools, you probably need a spanner wrench...
jafir
Feb 10, 2017 11:08 AM
Thatdudeuno1
May 1, 2012 05:10 PM
dino109
Jan 1, 2012 03:38 PM
rover1978
Sep 26, 2009 09:05 PM
