Fault code 4012 causing Three Amigos
I had been free of the Three Amigos for a little while but they have re-appeared and the code is:
Fault 4012 Pump Failure 1 (High level at X2 Pin 8 without pump actuation)
Any thoughts on a cause and how to fix?
Background: I previously had fault code 4022 Earth not connected to ground.
The ground wire to my ABS module was broken. I repaired the wire and cleared the code.
Which pump? ...................if the 3 amigos are showing it has nothing to do with the engine malfunction as they are different Control Unit's. There are multiple faults that create the 3 amigo scenario, battery power or earth grounds, wheel sensors or connections, SVS faults etc.
I cannot find any information on the cause or how to fix.
The pump and motor are the round lumps on the back of the modulator
https://www.ebay.com/b/ABS-System-Pa...560/bn_1421908
You will need to remove these to test the motor or replace the whole Wabco unit with a new or used item.
TBH I have never come across a pump/motor failure in a Wabco unit to date.
PS: Check with either Abran Abeyta or Paul Grant they may have a Wabco unit and/or have more knowledge of the ways to test them.
kbarker27
10-13-2023 04:03 PM
mx468
12-20-2015 10:47 AM
