Fault code 4012 causing Three Amigos
Old Aug 6, 2017 | 11:05 PM
JohnHZ3's Avatar
Default Fault code 4012 causing Three Amigos
I had been free of the Three Amigos for a little while but they have re-appeared and the code is:
Fault 4012 Pump Failure 1 (High level at X2 Pin 8 without pump actuation)
Any thoughts on a cause and how to fix?
Background: I previously had fault code 4022 Earth not connected to ground.
The ground wire to my ABS module was broken. I repaired the wire and cleared the code.
Old Aug 7, 2017 | 04:52 AM
OffroadFrance's Avatar
Which pump? ...................if the 3 amigos are showing it has nothing to do with the engine malfunction as they are different Control Unit's. There are multiple faults that create the 3 amigo scenario, battery power or earth grounds, wheel sensors or connections, SVS faults etc.
Old Aug 7, 2017 | 09:30 AM
JohnHZ3's Avatar
I believe the ABS pump. I was trying to do a power brake bleed with my Hawkeye and the ABS pump actuated for a few seconds but then stopped and would not come on again. I checked for codes and the 4012 code (Pump Failure 1 - High level at X2 Pin 8 without pump actuation) was present and cannot be cleared.
I cannot find any information on the cause or how to fix.
Old Aug 7, 2017 | 04:48 PM
The pump and motor are the round lumps on the back of the modulator
https://www.ebay.com/b/ABS-System-Pa...560/bn_1421908
You will need to remove these to test the motor or replace the whole Wabco unit with a new or used item.
TBH I have never come across a pump/motor failure in a Wabco unit to date.
PS: Check with either Abran Abeyta or Paul Grant they may have a Wabco unit and/or have more knowledge of the ways to test them.
Charlie_V
Aug 27, 2015 04:37 PM
br0keit
Mar 6, 2013 07:56 AM
vandal996
Feb 17, 2011 09:44 AM
