fault codes
Old Aug 10, 2007 | 02:50 PM
chargersfan's Avatar
Default fault codes
Took in for smog recieved fault codes P0300 and P0307. What are these and what do I do?
96 Disco
Old Aug 10, 2007 | 03:09 PM
dow's Avatar
dow
Default RE: fault codes
p0300 - multiple cylinder misfire
p0307 - misfire in cylinder 7
A code P0307 may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
google is my friend
Old Aug 10, 2007 | 06:22 PM
How many miles on your truck, when was the last set of plugs installed, how about plug wires, what octane gas are you using??
Old Aug 12, 2007 | 03:24 PM
ORIGINAL: Disco Mike
Hey Mike 148000 I'm going to replace all of those I have your list that you sent me on friday I plan on doing most of the work this coming weeked. I am running 91 octane, not sure what the guy before me was useing I'm going to email and ask.
Brian
Old Aug 12, 2007 | 05:20 PM
If you have any questions, get back to me and we can talk. Don't forget to order the Magnacor 8mm wires, you won't find then in an auto part store.
06Range
May 8, 2013 09:01 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
