Fault Codes, Losing Coolant, Gurgling behind Dashboard
Old Feb 6, 2013 | 11:46 PM
LADisco2's Avatar
Default Coolant Temp Normal Again
I bled the air out of the cooling system using the method suggested below and the running water sound behind the dash stopped. I topped off the tank and drove for a full 40 mins in stop and start city traffic. According to Torque Pro, the coolant temp rose to 91 degrees C and stayed there for the rest of the trip. As it had been consistently hovering around 105, that was a welcome change.
I will replace the O2 sensors and hopefully that will clear the codes.
And yet . . . if I'm getting service engine soon lean codes, have a slow coolant leak and the vehicle idles rough does that mean I have an intake vacuum leak? Do I need a new intake manifold gasket?
Thanks again.
Old Feb 7, 2013 | 06:03 AM
drowssap's Avatar
you still need to find that slow coolant leak, the number one killer of LR engines is Small coolant leaks. Beccause they are ussually a sigh of a large problem
Old Feb 7, 2013 | 01:47 PM
jfall's Avatar
If you must keep driving it, put a bottle of Barr's leaks into it.
This will slow down the leak.
If the leak is going into your oil - this may help a lot.
If the leak is going into the cylinders, the Barr's will do nothing.
Best not to add Barr's and not drive it.
But, if you must drive, use Barr's.
06Range
May 8, 2013 09:01 PM
EricTyrrell
Jan 2, 2012 06:39 PM
rod76
Feb 25, 2010 02:10 PM
walteroscar
Apr 28, 2006 10:10 AM
