Faulty service engine soon
Old Feb 21, 2017 | 12:31 PM
Carolynsdisco2's Avatar
Default Faulty service engine soon
Service engine soon light illuminates at start but will not pass emissions because it doesn't come on with problems. Emissions says faulty check engine light. I have 2000 disco 2
Old Feb 21, 2017 | 12:50 PM
Chrisw7562's Avatar
Have you had the codes read and then cleared? Either doing it yourself or having the guys at your local Napa/Autozone/AdvanceAuto doing it for you?
If there are truly no codes behind it all then that might clear up the SES light for you.
Old Feb 21, 2017 | 12:55 PM
I've not had them cleared. I will do that. Also the wire is broke above my transfer case box and from a different post it may have something to Do with it
Old Feb 21, 2017 | 01:05 PM
Chrisw7562's Avatar
It might (and also might not), we would need to know what the wire was...
I'd go have the codes read, write them down, and then have them cleared. Report back here with the codes and we can help. Also, if there are any codes, they might stay gone long enough to pass emissions and then you can deal with whatever is wrong.
Old Feb 21, 2017 | 01:10 PM
oh..ok. Well my maf code is on. So I'm going to replace that. I just did all 4 o2 sensors which cleared 4 if my codes. I have 2 left. The mag and the one that is a ghost but. Also they say my service engine light is malfunctioned. So I have one? Or just service engine soon
Old Feb 21, 2017 | 01:12 PM
I ment maf
Old Feb 21, 2017 | 01:43 PM
I ment maf
just took it to oreillys the code reading is p0102
Old Feb 21, 2017 | 02:06 PM
Chrisw7562's Avatar
Cleaning or replacing your MAF should take care of that code. Never heard of a code for a bad SES light. Hopefully taking care of the last code you have (p0102) would clear up your system and allow you to pass your emissions test.
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
AMANDAMC
Sep 23, 2007 11:14 AM
hippo2002
Freelander
Dec 19, 2005 01:31 AM
Woody Reems
Nov 29, 2005 06:08 PM
rinmud
Oct 1, 2005 04:32 PM
