Feel the burn
Old Jul 30, 2008 | 02:15 PM
Disco2Guy's Avatar
Default Feel the burn
I was hoping that I just needed to replace the ABS sensor for the front left wheel, but just got the call saying I also need the shuttle valve kit. Looking back at the service records the shuttle valve kit was replaced in June '04 about 40K miles ago. Tony (Cerrone) was hoping it was just the sensor, but another test with the Rovcom says it the shuttle valve too. Sigh...
Old Jul 30, 2008 | 05:20 PM
Default RE: Feel the burn
Replace the sensor and then wait and see. I'm betting that the shuttle valve is not the problem.
Old Jul 31, 2008 | 10:16 AM
D2G,
If you throw a panic stop at 30MPH plus, can you feel your ABS pulsate thru the brake pedal. if so don't replace the shuttle valve.
Is Frank basing your need for a new valve assembly based on the the code or has it in fact failed?
tsuami1
Aug 10, 2009 08:48 PM
03rangiemark
Detailing
Jan 16, 2008 03:22 PM
sailorcolin
Sep 11, 2007 08:00 AM
doeboy
Aug 8, 2005 11:56 AM
mikemeyer0
Apr 1, 2005 02:03 PM
