finally got the 3 amigos at 97k
ok about to drive to TX and got the 3 amigos this morning. Did a break job last week, bled the breaks, forgot to lube=brakes squeaking, lubed after I got the lights. No more squeak. Took a lil test drive and ABS and TC work. I contacted multiple repair shops and even called a few dealers and was unable to find anyone within 6 hours to do a scan, I am in lower Alabama at fort rucker. I contacted Mobile, AL and Baton Rouge, LA dealerships and neither could FIT me in on short notice.
Anyway obviously the lights won't clear themselves so I am stuck trying to find a repair shop/stearlership to get it fixed on my way to FT Hood,TX. Any help would be great
Thanks,
Rob
Thanks,
Rob
RE: finally got the 3 amigos at 97k
YOu could get into a shop here in Tulsa, but that's a little out of the way. Might see if there is someone in Dallas, it isn't too far out of the way. Houston is in your direction, but I am not sure how many shops are around. There has to be a place in Dallas.
I took it to a local shop here in AL and he had the wrong stuff, I guess he shouldn't advertise FOREIGN car repair. Anyway I found a repair shop in Lafayette, LA which is about 7 hours away but directly enroute to TX. I'll see what they can do.
I did a scan with my OBDII and got a P1590. From what I found on line no one really knows what this code means, but seems to be related to the 3 amigos. Truck is running great and ABS and TC work fine from what I can tell
Thanks
Rob
Thanks
Rob
bigbangtech
08-13-2012 12:22 PM
