finally got the 3 amigos at 97k
Old Feb 27, 2008 | 07:36 PM
robdis96's Avatar
Default finally got the 3 amigos at 97k
ok about to drive to TX and got the 3 amigos this morning. Did a break job last week, bled the breaks, forgot to lube=brakes squeaking, lubed after I got the lights. No more squeak. Took a lil test drive and ABS and TC work. I contacted multiple repair shops and even called a few dealers and was unable to find anyone within 6 hours to do a scan, I am in lower Alabama at fort rucker. I contacted Mobile, AL and Baton Rouge, LA dealerships and neither could FIT me in on short notice.
Anyway obviously the lights won't clear themselves so I am stuck trying to find a repair shop/stearlership to get it fixed on my way to FT Hood,TX. Any help would be great
Thanks,
Rob
Old Feb 27, 2008 | 11:51 PM
FJL's Avatar
FJL
Default RE: finally got the 3 amigos at 97k
3 Amigos happened to my DII at 90,000. Mike suggested that it was most likely a faulty sensor. My ABS still works as does my traction controll. I've been driving up and down the mountains on snowy roads all winter without issues.
Old Feb 28, 2008 | 01:41 AM
IDAHODISCO's Avatar
What is the three Amigos? Is it ABS, traction control and ???
or am I way off?
Old Feb 28, 2008 | 06:16 AM
zerochills's Avatar
3rd one is down hill decent
Old Feb 28, 2008 | 07:59 AM
okdiscoguy's Avatar
YOu could get into a shop here in Tulsa, but that's a little out of the way. Might see if there is someone in Dallas, it isn't too far out of the way. Houston is in your direction, but I am not sure how many shops are around. There has to be a place in Dallas.
Old Feb 28, 2008 | 05:02 PM
robdis96's Avatar
I took it to a local shop here in AL and he had the wrong stuff, I guess he shouldn't advertise FOREIGN car repair. Anyway I found a repair shop in Lafayette, LA which is about 7 hours away but directly enroute to TX. I'll see what they can do.
I did a scan with my OBDII and got a P1590. From what I found on line no one really knows what this code means, but seems to be related to the 3 amigos. Truck is running great and ABS and TC work fine from what I can tell
Thanks
Rob
drcoop
Mar 17, 2014 08:49 PM
bigbangtech
Aug 13, 2012 12:22 PM
seaosrover
Nov 14, 2010 03:07 PM
Analogkid
Oct 28, 2010 05:38 PM
lipadj46
Sep 12, 2009 07:31 AM
