Finally over heated
Old Mar 23, 2013 | 02:25 AM
FlyingZebra34's Avatar
Default Finally over heated
I heard that little fan coming on at idles and I chose to ignore it...
However I did order a new thermostat from Atlantic British so I have it on the shelf.
Right before the needle spiked (it didn't go all the way, maybe 3/4ths before I cut it off) the check engine light came on and I havent had the chance to pull the codes.
Any ideas on possibilities? She is running smooth btw.
Old Mar 23, 2013 | 02:33 AM
Code P1173
Old Mar 23, 2013 | 06:34 AM
coors's Avatar
P1173 Downstream fuel trim malfunction (bank 2) Front sensor aged - rear HO2S adaption too lean/too rich RH bank
http://www.canobd2.com describes the error as:
P1173 - Land Rover - Lambda sensor aging tv bank 2\nDrive cycle C:Signal out of range - above maximum.\n
Before ordering o2 sensors check the PCV for cracks or restrictions. Once you confirm there are no issues proceed to test the o2's.
vinnysca
Apr 1, 2016 05:37 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
Bayer
Jul 31, 2011 07:39 PM
jrm123180
Aug 3, 2010 09:42 PM
Benhamtroll
Dec 21, 2005 06:39 PM
