firing order help
Old Jul 10, 2007 | 05:10 PM
98roverguy's Avatar
Default RE: firing order help
I believe the first four are the top ones, then the second are the bottom. But not sure.
Old Jul 10, 2007 | 09:30 PM
EVN137's Avatar
I don't understand you. Are you talking about the coil or the cylinders? Is it's the engine, V8 gas engine firing order is pretty standard; cylinders 1,8,4,3,6,5,7,2. Your description four on top and four on bottom is the coil pack.....? If it is the coil, the respective cylinder connections are
top
1 6 5 8
left 7 4 3 2 right
bottom
cylinders 1, 6, 7, 4 connect to the left coil pack
cylinders 5, 8, 3, 2 connect to the right coil pack.
Ed
Old Jul 11, 2007 | 08:24 AM
George,
Do you have a check engine light, if so what are the fault code numbers?
Why don't you call me or send me your tele number and I'll call you.
Mike
mikeljacobs@comcast.net
Old Jul 11, 2007 | 09:47 AM
98roverguy's Avatar
1843
6572
8 7
6 5
4 3
21
Try that. I forgot to check my manual though.
Old Jul 11, 2007 | 09:53 AM
98roverguy's Avatar
Well I just ran out to check my 98, and it has the straight one-line coil pack not two. I don't know why you have a double rowed coil pack, maybe they changed that for the 99 DI. Can anyone who has a 99 DI verify this? Again, as Disco Mike has asked what exactly is the problem and when did it originate? Give Mike a call.
mumjo
Feb 20, 2010 08:10 AM
mx930
Dec 30, 2008 08:08 PM
jspbtown
Jan 3, 2008 05:39 PM
JBRIII
Jan 3, 2007 01:07 PM
bboat567
Jan 15, 2006 11:15 PM
