First DIY Oil change
RE: First DIY Oil change
ORIGINAL: avking
Someone earlier in the post said to replace the drain plug before removing the filter. If you leave the plug out when removing the filter, more oil will drain from the plug. Getting more out is a good thing, so do not replace the plug until after you remove the filter.
Learned a new thing today from this thread: Disco Mike mentioned reusing the oil drain plug ring by flipping it over and installing it on the oil drain plug. Will try it next time instead of using Teflon tape.
Heads up on preventing a mess in the driveway: Few oil changes ago, I removed the oil filter and installed a new one, refilled oil and started the engine. In less than a minute, I had few quarts of oil spewed on the driveway.
I did not pay attention to the oil filter rubber seal on the old filter that I had just removed. It remained stuck to the oil filter housing on the engine. The new filter was installed on top of it, which caused it to pop out after starting the engine.
What a mess to clean.
Ditto on the drain plug washer. I've never once replaced it, just flip it over. I don't know what genius marketing person spread the rumor about using a new one each time. Anything for a buck at LR. As a funny side note, I get e-mails from the local dealer LR dealer about their service specials - they include (and charge for) changing diff fluid every 7500 miles! We're talking soccer mom discos that have seen nothing but pavement, not mud and water crossings every weekend.
[align=left] [/align]
collin Barrows
08-28-2011 07:13 AM
