First DIY Oil change
Old Jan 22, 2009 | 01:34 PM
redhotbuzz's Avatar
Default RE: First DIY Oil change
If you can get a KN 3001 filter for 4 bucks get me case or 3
Old Jan 22, 2009 | 01:45 PM
brooksa's Avatar
I'm in on the case of $4 K&N filters! I just spent $13.00 on a Mobil because the zone was out K&N's.
Old Jan 22, 2009 | 02:06 PM
JBEGIN's Avatar
ORIGINAL: avking
Someone earlier in the post said to replace the drain plug before removing the filter. If you leave the plug out when removing the filter, more oil will drain from the plug. Getting more out is a good thing, so do not replace the plug until after you remove the filter.
too late i drained then put plag back in. didnt have filter wrench, it was on there pretty good had to punch screwdriver thru and twist off. Got all covered in oil, spilled my beer, spilled about a 1/4 quart oil on pavement... added 6 quarts oil and still low but looks fine enough to drive to where i can dump off used oil. now i wanna do the induction cleaning and have no idea where the hose is to suck the can in... goin to my neighborhood mechanic to ask for help. will keep posted.
Old Jan 22, 2009 | 02:43 PM
lrd2's Avatar
whats a good synthetic oil for a 2002 d2 with 98k miles? i have been using valvoline 20-50 synthetic blen but i want to start using full synthetic.
Old Jan 22, 2009 | 05:26 PM
Castrol Syntec 20w-50, or Mobil 1 15w-50 are both a good choice for where you live.
Old Jan 22, 2009 | 06:21 PM
unimoged's Avatar
Learned a new thing today from this thread: Disco Mike mentioned reusing the oil drain plug ring by flipping it over and installing it on the oil drain plug. Will try it next time instead of using Teflon tape.
Heads up on preventing a mess in the driveway: Few oil changes ago, I removed the oil filter and installed a new one, refilled oil and started the engine. In less than a minute, I had few quarts of oil spewed on the driveway.
I did not pay attention to the oil filter rubber seal on the old filter that I had just removed. It remained stuck to the oil filter housing on the engine. The new filter was installed on top of it, which caused it to pop out after starting the engine.
What a mess to clean.
Old Jan 22, 2009 | 06:36 PM
jdelp's Avatar
Ditto on the drain plug washer. I've never once replaced it, just flip it over. I don't know what genius marketing person spread the rumor about using a new one each time. Anything for a buck at LR. As a funny side note, I get e-mails from the local dealer LR dealer about their service specials - they include (and charge for) changing diff fluid every 7500 miles! We're talking soccer mom discos that have seen nothing but pavement, not mud and water crossings every weekend.
[align=left] [/align]
Old Jan 22, 2009 | 06:55 PM
sloppyjoe's Avatar
the older ferraris use a copper o ring on the drain plug.
every other change i just take a propane torch and heat up the copper to let it expand. then i let it cool and it works over and over
Old Jan 22, 2009 | 07:59 PM
Its not just LR that says to replace the crush washer at every oil change, I never replace mine either.
You can buy a million of them for a dollar, but why when you can reuse your old one.
collin Barrows
Aug 28, 2011 07:13 AM
Memphy03
Apr 2, 2009 01:09 AM
lipadj46
Mar 8, 2009 08:44 AM
tsuami1
Sep 3, 2008 09:20 AM
bigugly82
May 15, 2007 02:57 PM
