First DIY oil change.
Old May 13, 2007 | 03:55 PM
bigugly82's Avatar
Default First DIY oil change.
'03 Disco II 43K miles (out of warranty)
Just a quick check to vfy from previous posts.
20/50W and 6qts of ATF for the flush, K&N 3001. Correct?
Old May 13, 2007 | 05:42 PM
Default RE: First DIY oil change.
If you want to do a HD flush, then yes, 6 qts of ATF, let it idle for 20 minutes then do your normal oil change.
Mike
Old May 14, 2007 | 11:31 AM
Landzu's Avatar
ORIGINAL: bigugly82
10w40 summer/ 5w30 & 5w40 winter with at leasted SJ / SH
API rating or better.
Old May 14, 2007 | 05:40 PM
bigugly82's Avatar
I'm in San Antonio, TX. Do I really need a different weight in the winter?
Old May 15, 2007 | 08:08 AM
NO you can use the same weight all year around. While I lived in California I always ran 20/50W because of the mild climate, here in Colorado, it is 5/30W in the winter and 10/40w in the summer when I am playing harder.
Mike
Old May 15, 2007 | 08:29 AM
Landzu's Avatar
ORIGINAL: bigugly82
I just like the fact that the lighter oil gets to the top end faster.
And only run it in Nov, Dec and Jan here in Dallas Tx.
I found that 15w50 Mobil One synthetic took to long to get to the
top end, even inthe summer.
So I just use the 10w40 the rest of the time.
I have 107K on my truck , the motor is still tight.
Thick oil for motors that need to make up the opened tolerances.
Old May 15, 2007 | 08:40 AM
Aquaholic's Avatar
I like Shell 5-40 synthetic, all year in Austin, TX.
Old May 15, 2007 | 09:44 AM
ORIGINAL: Landzu
ORIGINAL: bigugly82
top end, even in the summer.
How are you determining what oil gets to the top of your engine first? Is it by internal engine noise at start up, if so you might want to look at the brand of oil filter your are using, sound s like your filter is not holding its oil and bleeding down over night.
Mike
Old May 15, 2007 | 02:57 PM
Landzu's Avatar
[/quote]How are you determining what oil gets to the top of your engine first? Is it by internal engine noise at start up, if so you might want to look at the brand of oil filter your are using, sound s like your filter is not holding its oil and bleeding down over night.
Mike
[/quote]
Land Rover Filters or Mobil One Oil filters same sounds.
When you live with something for awhile you know.
Its the little sounds that you key on.
After working on cars for 27 years you just know.
collin Barrows
Aug 28, 2011 07:13 AM
Memphy03
Apr 2, 2009 01:09 AM
lipadj46
Mar 8, 2009 08:44 AM
JBEGIN
Jan 22, 2009 07:59 PM
tsuami1
Sep 3, 2008 09:20 AM
