The fix
Old Jan 7, 2019 | 02:51 PM
  #21
Saturnine's Avatar
Probably not a whole lot of difference but these engines are already running on the hot side compared to other V8's generally speaking
Old Jan 7, 2019 | 03:02 PM
  #22
CollieRover's Avatar
Originally Posted by Sixpack577
One more thing.
CollieRover, didn't you have your upper and lower intake and valve covers powder coated?
If so, did you notice any increase in operating temperatures, even a degree or 2?
I have always read that painting or coating aluminum reduces it's ability to dissapate heat.
I'm not overly concerned about underhood looks, as long as things are clean, but wouldn't mind the aluminum not oxidizing and the engine be covered in white powder.
It's very humid where I live, and even after the truck has only been sitting a couple days, the engine gets covered in oxidation before the moisture can be burned off.
I used Duplicolor engine paint. I mainly did it because the aluminum is just so dang dirty and impossible to clean.
Painted the top end including brackets, no increase in temps, wipes clean. Makes me happy looking at it.
Best results were from using only paint, no primer/clear, bake at 300 for 30 minute after painting if u can. Otherwise it cures in the engine bay.
Old Jan 7, 2019 | 03:21 PM
  #23
Sixpack577's Avatar
Thanks for the info, I may try it.
Just depends how fast I try to get it back together.
Paint is no good in the cold, and even spraying in my garage with a heater and respirator, I have to open the door a little for ventilation...and it gets cold in there fast.
I could bead blast the parts and work, and use a high temp clear or silver.
What the heck right, these things eat money anyway, lol.
Old Jan 7, 2019 | 03:41 PM
  #24
What is manifold dressing?
I'de love to have some sort of coating that wouldn't burn off, just to keep the rust off.
I really wouldn't want to spend the money on ceramic coating, and also wonder if the extra heat that it doesn't allow to escape would be too much extra heat in the cats.
Wasn't it NoDoubt that wrapped his manifolds in heat tape, but had to remove it because the cats were glowing?
Is there no CollieRover porting by mail service offered yet??lol
You also are Not helping, only making my "to-do" list longer, lol!
Got the dressing from Eastwood. I dipped the manifolds in rust remover. It looks good 3500 miles later, but there is rust leaking thru here and there. It smoked like crazy curing, don’t sniff the fumes!
Old Jan 7, 2019 | 03:47 PM
  #25
There is countless info on porting out there, and I know how it's done, and have done it before.
But, I'm always interested in the details of how each person does there's.
What did you use to mark the material you removed?
I have used Prussian Blue years ago, but am sure there are lots of products.
And, if I open up the exhaust ports on the heads(I know too much is bad for several reasons)...then I have to grind more out of those hard cast iron manifolds.
I know the benefits, and am glad to hear good real world results on a LR engine from someone who's done it...but still seems like alot of work.
I have carbide bits for my Dremel, and I think that would be quick and easy on the aluminum heads. But, on cast iron, I think they would work well, but not last nearly as long, and that it would take a long time to do.
Especially since this is really a once you start it, you have to follow through and finish it type job.
The 1/4” die grinder and carbide bits had no issues with the cast iron. I just used sharpie, but I wasn’t pushing any of the porting to be ultra close to the gaskets. I can’t speak to the dremel carbide bits.
Not much to be done on the intake side of the head really. Some decent removal on the head exhaust ports and the most material I removed was the exhaust manifold. If I was to only do one spot thatnwoild be it.
Old Jan 7, 2019 | 03:48 PM
  #26
i had to paint outside and fought the weather as well. Had the machine shop do a good bit of the painting.
Old Feb 7, 2019 | 09:57 AM
  #27
redwhitekat's Avatar
Post some of your fixes so we can all help each other
Old Feb 8, 2019 | 07:24 AM
  #28
jastutte's Avatar
was getting a recurring Camshaft Sensor Code. knowing this code could sometimes indicate the CrankShaft Sensor instead, i changed that. continued to get the Camshaft Sensor Code. Changed the Camshaft Sensor. continued to get the Camshaft Sensor Code.
happened to notice that the wire loom containing the wiring for the Camshaft Sensor had come loose and was resting against the exhaust manifold. one of the wires for the Camshaft Sensor had burned all the way through and was hanging in two separate lengths.
i tracked down a similar sized wire that i had lying around, cut it to length, soldered it in place and then used liquid electrical tape to seal it all up. put new wire loom wrap around all the wires and zip-tied them out of the way. no codes and trouble free since.
Old Feb 8, 2019 | 09:24 AM
  #29
NewToTheTwo's Avatar
Cruise control not working - hoses new - button works - diaphragm test was good - replaced the vacuum pump - $25 used and fixed the problem
Not "fixing" anything necessarily, but something mentioned here but rarely hear folks actually doing - grease everything.
I took off all of my door panels, including the rear door - greased everything I could get to - hinges, locks, windows, the window felt tracks, everything I could see or reach.
Vet MB mechanic recommended dielectric grease for the felt strips - used a long cotton swab
Old Feb 8, 2019 | 10:29 PM
  #30
Good info folks we are all here to help
what is a vacuum pump ??
