Fix that big hole in your auto transmission
Old Dec 31, 2019 | 07:36 PM
PPorBust's Avatar
Default Fix that big hole in your auto transmission
No, not the one shaped like the end of a drive shaft
I was surprised the first time I crawled under my Disco 2 and looked around. Something was clearly missing:
Turns out that is an inspection window to allow a peek at the torque converter. The hole is supposed to be covered with a little metal plate. A little metal plate that costs $25.
Since I'm a CSOB I went a different route. First I took a "rubbing" and punched the hole locations with a pencil:
Then did some trig:
Made a PDF file and took it to the laser cutter at work. In a flash (which you're not supposed to look at) I had this:
Okay, so 1/8" acrylic is kind of a ridiculous choice of materials, but it was there, and the laser can cut it.
I bought three bolts from the local hardware store (M6 x 16) and viola:
Fit just right.
Anyway the part isn't mission critical but it is nice to have. Anybody that needs one (and doesn't have access to a donor vehicle at the pick n pull) can either:
a) print the PDF and use it as a template to cut one out of sheet metal.
b) use a laser cutter to make one out of something easily cuttable but no so great mechanically (acrylic, plywood...)
c) send it to some company with a *real* laser cutter, plasma cutter, CNC, etc. I'll bet it's not too hard to get it done for under $25!!!
Carp. I thought I had the PDF on my phone. I'll post it tomorrow.
Old Jan 1, 2020 | 07:18 AM
Sandman614's Avatar
Nice job, reminds me of this
Old Jan 1, 2020 | 04:30 PM
shanechevelle's Avatar
$2 and a trip to your local yard.
Old Jan 1, 2020 | 07:17 PM
Extinct's Avatar
3d print is another option - although it gets pretty warm down there.
Old Jan 3, 2020 | 07:51 AM
greisinb's Avatar
I would recommend swapping the acrylic out in the near future, it is a very brittle plastic and not impact resistant. I would recommend PETG, a laser cutter can cut it and it’s impact resistant. Don’t try and cut polycarbonate on a laser, it’s bad news!
greisinb
Nov 13, 2019 11:55 AM
trailguy90
Aug 17, 2016 12:14 PM
pinkytoe69
Mar 31, 2016 12:34 PM
Dezert Rover
ROAMING WITH FRIENDS
17
Jan 1, 2011 06:34 PM
Street Wolf
Sep 13, 2009 11:17 PM
