Fix oil leaks or replace engine?
Old Dec 20, 2009 | 11:35 AM
Originally Posted by Scott R
If you want to own an older car be prepared to replace the mains, they don't last much more than five years on any car.
I disagree.
My truck does not leak engine oil and it is all original with just shy of 186k on her.
I agree that seals need to be replaced eventually, but they last longer than 5 years.
Old Dec 20, 2009 | 01:01 PM
lipadj46's Avatar
You beat me to it, rear main seals should last longer than 5 years with proper oil changes. An oil seal crumbling after 5 years sounds like there was something else going on, maybe it was defective. Also there is nothing wrong with using a high mileage oil and or a seal conditioner/sweller in order to help stop a seeping rear main seal or front drive shaft seal leak. If you are using a thicker oil in order to stop oil consumption because of bad valves or whatever other engine problem then yes you should be saving up for a rebuild, a thicker oil can definitely buy you time though.
Old Dec 20, 2009 | 01:26 PM
Suede's Avatar
Buy yourself one of these :
And take your wife on vacation to Hawaii with the savings. You wouldn't spend $2100 on a new paint job due to a scape the size of a penny. That's more than 1/3rd the value of the vehicle for what is essentially a cosmetic problem.
Tighten the valve covers (10 minutes) & Drop the oil pan, clean the mating surface, and reinstall in an afternoon. 90% of your little leaks are sure to disappear, and the above pan will catch the other 10%. Be sure to send me pics from Hawaii with your wife standing next to ya with that huge smile on her face!
Old Dec 20, 2009 | 02:30 PM
Scott R's Avatar
Originally Posted by Spike555
I disagree.
Not on these, the fit is poor on the case. At my low milage I could rotate the seal right out of the boss both the front and rear. It was brittle and worn, the material is just cheap.
I've yet to see one and I buy a few a month for my business that's not seeping at the rear. It may not be leaving a puddle, but it's probably leaking. For my truck it was a combination of a new seal and Curil-t that stopped the leaks. And I don't expect to not start seeping again in five years.
Old Apr 20, 2013 | 08:46 PM
Lord Wert's Avatar
This conversation made me feel better.
Old Apr 20, 2013 | 10:53 PM
Rover_Hokie's Avatar
I cannot get the picture to load, what is it?
Old Apr 20, 2013 | 11:10 PM
jthomas's Avatar
From reading the rest of the post, I'm guessing an oil change drain pan.
Spencerfitch
Sep 27, 2020 12:17 PM
austinlandroverbill
Aug 23, 2015 01:03 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
KRMusher
Feb 15, 2013 07:33 PM
discoboy
Dec 20, 2012 02:24 AM
