Fixed steering shake/jerk with new tires
This wont be a fix for everyone, but thought it could help someone with a similar setup and issue.
My D2 had some worn tires when I bought it. They were Continental CrossContact SSR UHP run-flats. Though they were not quite down to the wear bar, they definitely needed replacing, but I held off for a few months as I was not sure if the engine would hold up.
In that time, I would get a bit of a shake in the steering when going over certain bumps/holes at mid to high speeds. Also, when changing lanes on the freeway or simply having one tire go over a different surface (ex: concrete to asphalt) the steering wheel would jerk in the direction of the new surface. It was not a safe situation.
Now that the engine has proven to be sound enough (knock on wood) and with winter coming it was time to address the issue. I figured I would have to replace all sorts of steering and suspension components, but started with tires as they definitely needed to be done. Got a new set of Cooper Discoverer+ and holy cow what a difference.
Through 2 weeks all the weird behavior is gone. The Pepboys guys said those run-flats had sidewalls about 3" thick and needed 2 prybars to get them off the rim. I assume that was part, if not all, of the handling issues.
Anyways, heads up to be careful of run-flat tires on a D2
bcolins
09-25-2012 08:40 AM
