flashers
Old Sep 14, 2008 | 04:57 PM
Darover's Avatar
Default flashers
Gents, noticed on my way to my inlaws, that when using my front left flasher, it would click at a beat twice as fast as usual???. It has done it on a few occasions before, but when I wanna to check it, it stopped doing it. What is it??? bad connection??? burned light or what. Still at my inlaws right now and it's pouring rain outside so I'll have to check later.....But wadaya think????
Old Sep 14, 2008 | 05:34 PM
Default RE: flashers
If it were doing it all the time it would be a burnt out light bulb. But becuase it is intermintent it is a loose bulb, hit a bump, loose, hit another bump, not loose.
Check the bulbs in the rear bumper, those light sockets go bad. They get lots of water and road grime/salt and it eats the bulb socket holder away. I replaced both of mine because of the same problem. $5 part at atlanticbritish.com. Not sure if they ship to you in Canada though.
5 min fix once you get the new part.
Old Sep 14, 2008 | 06:15 PM
Darover's Avatar
Checked on my way out since it had stopped raining, and it is the front left corner flasher that doesn't work. I'll check tomorrow to see if it is loose or burned.
Thanks, Spike!!!
Old Sep 18, 2008 | 09:49 PM
Darover's Avatar
Problem ended up being that the connection was dirty and a bit rusty. Cleaned it with WD40 and then packed the connection with dialectric grease. Reconnected it and all is fine.
JPSpen
Dec 3, 2012 02:15 AM
58ford
Jul 13, 2011 06:07 AM
happycamper
May 4, 2010 02:01 PM
Brad S1
Apr 21, 2008 04:33 PM
Drnknmnky13
Jul 5, 2006 06:54 PM
