Flashing "M" and "S" loss of power
Old Feb 14, 2009 | 08:32 PM
caustin's Avatar
Default Flashing "M" and "S" loss of power
Very new to forum I have been reading threads and found several interesting things. There were a couple of threads on this issue but not sure if they apply to my issue.
I have disco II '02. While driving, I will come to a stop and the "M" and "S" flash and I loose power it is very slow to accellerate. Turning off the vehicle and restarting seems to fix it for the moment. Please advise.
Old Feb 14, 2009 | 08:52 PM
First have your battery and alternator teseted.
Is your check engine light on?
Old Feb 15, 2009 | 10:00 AM
How many miles on your truck? As Spike mentioned, go have your battery/alternator tested, low voltage, from a failing battery or dirty cables, can cause this and will get so bad that you may not be able to drive the truck or only drive in limp mode.
Old Feb 15, 2009 | 03:53 PM
caustin's Avatar
I had the battery checked and the altenater checked last summer. They were all good. I will get those checked again. It happens more often in the warmer months.
68,000 miles.
Old Feb 15, 2009 | 04:07 PM
It happens more often in the warmer months...like when the A/C and headlights are both on?
Alot can happen in a year.
Car batteries only last 4-5 years.
Old Feb 15, 2009 | 04:14 PM
Get your system rechecked again cause if it isn't this than you have a major problem and you don't want to be driving the truck.
importdave
Sep 25, 2014 10:18 PM
dkak
Oct 1, 2013 12:49 AM
hollis
Jul 30, 2011 04:47 AM
ontheroadagain
Mar 27, 2008 08:10 PM
gsgtsg
Jan 23, 2008 01:46 PM
