Flashing Odometer Reading on 2000 Disco 2
Old Sep 15, 2018 | 06:33 PM
droddisco's Avatar
7th Gear
Default Flashing Odometer Reading on 2000 Disco 2
Whats the fix on my flashing odometer reading? It’s also not lit for nighttime driving.
Old Sep 15, 2018 | 06:45 PM
toofaroffroad's Avatar
Ok well that is probably 2 different things. There is a small green bulb that can be changed in the dash. I found instructions somewhere on this forum to do that fix. The bulbs are also cheap.
The flashing odometer can be caused by as few different things. Mine has been flashing for over 2 years. When I first bought the truck i found out after driving for 15 minutes that the alternator was shot. She crapped out and all the dash lights came on. When I had fixed it the odometer was still flashing. If you want it fixed you'll need a tool that can fix and diagnose LR engines. Something like a Nanocom or a Hawkeye. Maybe a local dealer or Euro car repair place could help you out. Good luck.
Old Sep 15, 2018 | 06:54 PM
Best4x4's Avatar
Yep you'll have to get the BCU/Intrument Cluster Synced back together and all will be well or have the Odometer flash option disabled in the BCU.
Red320
Apr 29, 2018 09:07 AM
bcolins
Feb 22, 2014 09:22 AM
aarons02
Feb 25, 2011 06:34 AM
2005bigbody
Dec 19, 2010 09:47 AM
dp_roberson
Apr 29, 2005 12:24 AM
