Flex-A-Lite 180, Motorad 180 Thermostat, Evans Waterless Coolant experience
Old Jun 18, 2020 | 11:22 AM
  #121
Dave03S's Avatar
Thanks for the update, The next chance I get I will go back to the stock setup and delete the E Fan. Just to be clear, for cooling purposes, the E Fan works exactly the same as stock in my setup...
You've discovered my main problem with an electric fan... When the alternator fails you have all the load of the fan on the battery which draws it down very quickly compared to stock. If your alternator failed off grid you would be stuck with no way out.
My alternator failed while driving on the freeway. The battery lasted about 20 minutes. Obviously you can't just turn off the fan to decrease the load and extend your ability to get back to civilization.
Old Jun 18, 2020 | 12:11 PM
  #122
CollieRover's Avatar
My experience mirrors yours. I am disappointed, as I spent time and money on the install, but that is OK. You live and you learn.
I didn't notice any change in gas mileage or temp, and those were my main goals.
Old Jun 18, 2020 | 01:05 PM
  #123
Sixpack577's Avatar
And, get the electric fan wet and it dies.
They are no good off road for that reason.
I have seen 2 non factory e-fans fail 4wheelin(not D2's), and there they sat, overheated.
rtarh2o
Jul 19, 2015 07:11 AM
cosmiccharlie
Jun 5, 2013 10:09 PM
mx468
Apr 29, 2013 08:08 PM
Rearden Steel
Jan 29, 2013 09:19 PM
MC04DII
Dec 5, 2012 10:14 AM
