Flexible coupling.
Old Sep 20, 2022 | 01:47 PM
Mullins.cody's Avatar
Default Flexible coupling.
Planning on changing out the flexible coupling. Noticed some pretty bad cracks while doing other maintenance. Have seen some say that the coupling has to be installed facing a certain way or it could wear out prematurely. The rave doesn't mention it. Just says make sure the bolts are shooting the correct way.
Old Sep 20, 2022 | 11:08 PM
Karmakannon's Avatar
There should be little arrows molded into it and if I recall the bolts face with the arrows. I did a slightly larger bmw coupling. Didn't fix my driveshaft vibes, but it is a little thicker. No idea how it will last because it's only been 500-1,000 miles.
Amazon Amazon
I actually used hose clamp and a washer to replace a missing weight on the rear shaft and when that didn't work I removed the washer and left the clamp thinking I'll try a bigger washer later. I guess the hose clamp was enough to almost remove all driveshaft vibes!
Old Sep 21, 2022 | 06:58 AM
jastutte's Avatar
https://www.amazon.com/gp/aw/d/B00BDVL6D0
nice find on the crossover part!
always good to have options for these Rovers.
Old Sep 21, 2022 | 07:59 AM
I'm cheap and the risk was pretty low for that price. I figured under $50 and it's a little thicker... Hey, might be worth it!
Old Sep 21, 2022 | 12:29 PM
ahab's Avatar
Meyle is a much better brand and only a few dollars more for their HD version. And if you buy it here there is a lifetime guarantee so it will be the last one you ever have to buy if it fails.
https://www.fcpeuro.com/products/bmw...d-3141523102hd
The arrow on the flex coupling points to the flange you are bolting it to, and the bolt itself follows the direction of the arrow, with the nut on the other side of the flange.
Old Sep 21, 2022 | 09:09 PM
nashvegas's Avatar
The RAVE does mention it
Old Sep 22, 2022 | 10:13 AM
ahab's Avatar
Oddly, those two pics are contradictory. The one on the right is correct.
Old Sep 26, 2022 | 09:01 PM
How hard should it be to compress and extend the driveshaft. I was putting my whole body into it to compress it. Then the same extending it plus I bent the jack handle it was so stiff. Anyone else have this problem?
Old Sep 27, 2022 | 07:19 AM
mollusc's Avatar
The spline should slide pretty easily. Could yours be bent?
Old Sep 27, 2022 | 09:21 AM
I couldn't tell by looking at it when I was working down there. It does have a slight vibration accelerating from like 30-60 ish. Any other way to tell?
Richard Gallant
Apr 23, 2021 07:18 PM
Sam95disco
May 25, 2012 06:02 PM
Bryan H
Jul 25, 2010 07:15 AM
03discoman
Dec 28, 2009 02:43 PM
