Flowkooler water pump now available?
Old May 19, 2022 | 12:11 PM
  #81
Blamo35's Avatar
Originally Posted by SWM
I think most have recommended and I plan to: a thin layer of RTV on both sides, hand tighten the bolts and let sit overnight then tighten to spec next day.
Thanks, thats what im gonna do. What are the torque specs?
Old May 19, 2022 | 01:24 PM
  #82
SWM's Avatar
SWM
Old Apr 22, 2025 | 07:35 PM
  #83
ACEBROKE2's Avatar
Is there a follow up thread on these Flow Koolers? I just ordered one. Am trying to find where to buy new bolts if anyone knows.
I should've asked this before buying .. but does the increase in flow increase PSI and put more strain on the head gaskets.
My head gasket job is old, like, really old.
There is a coolant leak dripping from the bottom of the window washing tube. This happened after I changed the Fan but did not change the clutch.
Old Apr 23, 2025 | 09:04 AM
  #84
WaltNYC's Avatar
AB sells bolts, but they are bolts and washers and not even all metric. Truly dumb.
The best place I have found to buy metric flanged bolts is Bel metric.....
https://belmetric.com/bolts/hex-flan...5D%5B0%5D=10mm
Not sure a new coolant pump would do damage unless the HG was about to blow out anyway. Seems unlikely. The pressure cap on the reservoir is 15 psi IIRC.
Coolant in the windshield washing tube? That doesn't sound right.
Old Apr 23, 2025 | 01:07 PM
  #85
JohnZo's Avatar
Water pump does not increase pressure on the head gasket. It can increase suction on the tube from the radiator, so make sure that is in good shape with no flat or soft spots that could collapse. Good to replace old rubber tubes.
For my D1, a kit of water pump bolts from AB was only fairly good because a few did not fit. Remember to seal the threads on the long bolts that go into the block water passages.
Old Apr 23, 2025 | 01:40 PM
  #86
ACEBROKE2's Avatar
Are those the bolts for the water pump in the link?
Old Apr 23, 2025 | 01:44 PM
  #87
ACEBROKE2's Avatar
It's dripping out of the bottom of the tank, where the tube connects. I installed a Doorman 620 fan but did not install a new clutch or a new water pump.
Adde7711
Feb 9, 2024 12:01 AM
Gripen
Jan 31, 2018 06:40 PM
austinlandroverbill
Oct 28, 2017 12:43 PM
Honey Badger
Dec 11, 2013 06:50 AM
lipadj46
Nov 15, 2009 10:36 AM
