fluid drops on bottom of front shock
My '03 seems to sit about 1/2" to 3/4" lower in the front on the right than on the left side, measuring from the top of the tire to the fender flare. I don't see a leak, but this could've happened prior to my purchase. Is this most likely a bad shock, or could it be something else?
It does have ACE, but I didn't think that had anything to do with what I'm seeing.
it should be equal measurements both sides. If there is a large discrepency and you are still running the original springs maybe they are now 'tired' and past their sell by date, similarly the shocks. The shocks shouldn't affect ride height stationary as the truck is loaded onto the springs only at that point. The only time the shocks come into play is when you jack the bodywork up and the full extension of the shocks limits the droop on the axle. Hence, you never jack up the rear bodywork without the shock fitted if you have air springs (SLS) or you'll ruin/rip the airspring(s) out of it's seating(s).................. comprenez vous.
Thanks for the info.
I was sent the TF lines by mistake from L8 but I sent them back to get the Goodridge. I think they are the exact same lines (same yellow tag for the name and everything) just a different name and a little cheaper. They probably would have worked just fine but I wanted the Goodridge name for some reason and I'm willing to wait longer and pay a little extra to get them. Maybe the Rover is driving me insane.
Also bought the Goodridge set and then realized under TF on their old website they had the cheaper line kit. Spares ftw!
Also if it was a pin hole, I'd imagine you would have the pedal hit the floor at least once. Not a good feeling for sure.
Heads up, the banjo bolt didn't fit the brass spacers so I reused the old ones.
atikovi
Mar 27, 2016 09:05 PM
