Foam strip for ventilation air intake
For those of you who have replaced or installed a foam strip over the ventilation air intakes on these trucks, what have you used other than the dealer foam-which is very expensive. I need to replace mine but would like to know what aftermarket foam/insulation has worked.
foam strip
Hello from Scotland.
In the UK there is a TV sales channel QVC, which I think is in the USA also.
Whenever they post purchases in the UK they all have foam packing strips for protection inside. Each strip is 6"long by 1" square and fit perfectly inside the intake.I used them in my Discovery 1 and they are super.Ask among friends who buys from QVC and get the strips.Hope this helps.Best part is they will be FREE.
cheers
Jim Anderson Discovery 1996 300Tdi auto(Jap reimport)
cheers
Ref Discovery 2 - Foam strip for ventilation air intake (replacement)
My foam had all but crumbled away, and non of the local air conditioning providers could help, let alone the Land Rover dealers!!!
I found that dish washing scouring pads (green things) available from supermarkets work a treat. Simply cut to size and slot in. Cost? AUS$1.15.
And all but indestructible.
Job done!
Job done!
Not expensive at all. Just order this one and install. Takes about 3-5 minutes. Done.
Filter Pollen (Genuine Part # JZL100120) - Land Rover pcv & pollen/cabin filters from Atlantic British
-aaron
2003 SE7 125,000 miles
-aaron
