Fog lamp wiring for driving lights?
Old Jan 5, 2015 | 10:53 AM
bballjames's Avatar
Default Fog lamp wiring for driving lights?
So it's been a while since I've posted... life has been a little crazy the last few months.
I'm going to be ordering a new bumper here in the next couple weeks, and I have factory fogs in mine now. I would like to use the existing wiring and hook up some driving lights... is it that easy? or do I have to run new wiring?
Old Jan 8, 2015 | 12:26 AM
bballjames's Avatar
Where's Buzz when you need him...
Are SavannahBuzz and DiscoMike around at all anymore?
Old Jan 8, 2015 | 08:48 AM
Richard Moss's Avatar
Are you planning to use the driving lights instead of the fogs or as well as? The fogs are probably 55w each so a total of 110w which means about 9 amps.
Check the fuse rating for the front fogs (see the handbook). If it's 10 amp then you could use up to 110w of driving lights (55w each) and a 20 amp rating would allow you to use double that.
Old Jan 8, 2015 | 10:20 AM
bballjames's Avatar
Thanks for the reply. Ya I was planning to use the driving lights INSTEAD of the fogs. I'll dig into the rave and see what I can find as far as wattage and amps.
Old Jan 8, 2015 | 10:30 AM
PaulMc's Avatar
The front fog lights are protected by a 15A fuse (F3 in the engine compartment fuse box), and are wired in 1.5mm² cable (20A rated).
Old Jan 8, 2015 | 11:49 AM
Madlands's Avatar
I am running a pair hella 500's off my stock fog wiring. They work just fine.
Old Jan 8, 2015 | 12:24 PM
bballjames's Avatar
Excellent. Thank you all for the info.
Old Jan 8, 2015 | 02:10 PM
Bom2oo2's Avatar
Correct me if I am wrong, but on 04 when fog,s are on if I turn high beam, fog's turn off , is it different In 2000 model? Because if it's same way U won't have driving- lights and high beams on at same time if U want max visibility, ( maybe U can twick the wires so they come on together, but I don't know how.)
Old Jan 8, 2015 | 02:15 PM
PaulMc's Avatar
The BCU settings can be changed to allow front fog lamps to be illuminated at the same time as the main (high) beams.
I posted some info on this, here - https://landroverforums.com/forum/di...-lights-66143/
Old Jan 8, 2015 | 02:58 PM
Bom2oo2's Avatar
Thank u PaulMc, very nice! I have a (Icarsoft930) scanner u think it can change the setting?
