fog lights.
Get yourself a factory front fog light switch and install it down by the cruise master switch. That's where the factory fog light switch goes. You really don't want your rear fog lights coming on every time you want your front fog lights on. The picture shows my switches; driving lights, fog lights and cruise - left to right.
OK - i found the right fog lamp wire attached to the frame below the front right headlamp. On the left side that area is obscured by the washer bottle. I noticed there are two vacant plugs in the left headlamp opening, one is exposed and looks like (-.-), the other has a jumper wire in it. Any idea which one is for the left foglamp? I could put a tester on it but haven't had the shop turn on the code for it yet. Also have to trim the switch to get it to work in the middle of the binnacle. Any guidance here is much appreciated. 2002 D2 SD
