fog lights.
Old May 27, 2009 | 12:39 AM
tango123's Avatar
Default fog lights.
I have a 97 series 1 disco. I just want to know where's the safest place to drill a hole in the firewall in order for me to wire up the switch for my aftermarket fog lights?
Old May 27, 2009 | 09:24 AM
There are plenty of inlets going thru the fire wall, use any of them and don't drill an extra hole.
Are you going to use one of the Rover switches that is already installed?
Old May 27, 2009 | 02:43 PM
tango123's Avatar
Thanks for the advice. Yes, I'm planning to use the factory installed rear fog light switch(I'll be putting a relay) instead of using the aftermarket switch that came with the fog lights. I heard it was doable. Any tips or precautions that I should be aware of?
Old May 27, 2009 | 04:53 PM
AK Rover's Avatar
Get yourself a factory front fog light switch and install it down by the cruise master switch. That's where the factory fog light switch goes. You really don't want your rear fog lights coming on every time you want your front fog lights on. The picture shows my switches; driving lights, fog lights and cruise - left to right.
Old May 28, 2009 | 10:21 AM
okdiscoguy's Avatar
Even if you don't have factory fogs, the wiring is still there, behind the switches, tucked away. The connections are already by the headlights. Just wire your lights into there, plug in the switch, and pop a relay in the harness behind the drivers kick panel...
Boom factory lights.
Old Jun 1, 2009 | 06:22 PM
gilder's Avatar
OK - i found the right fog lamp wire attached to the frame below the front right headlamp. On the left side that area is obscured by the washer bottle. I noticed there are two vacant plugs in the left headlamp opening, one is exposed and looks like (-.-), the other has a jumper wire in it. Any idea which one is for the left foglamp? I could put a tester on it but haven't had the shop turn on the code for it yet. Also have to trim the switch to get it to work in the middle of the binnacle. Any guidance here is much appreciated. 2002 D2 SD
Snowdog
Apr 7, 2016 01:05 PM
Frank4
Nov 21, 2015 05:47 PM
abran
Oct 1, 2013 09:09 PM
jordamf
Aug 2, 2011 09:04 AM
mikemeyer0
Apr 1, 2005 02:03 PM
