fog lights only come on when high beams are on
Old 06-06-2018, 08:45 PM
hankeester's Avatar
Originally Posted by Best4x4
Normally the T4 was just able to tweak the fog light on/off setting. The Aux lights had their own wiring harness/relay and can't be programmed. However if it's wired like I'm thinking it's very simple to switch em over.
The Aux setup uses a relay, it gets a trigger input to the relay whenever high beam is selected because the trigger input is tapped into the high beam circuit. All you'd have to do is disconnect the high beam wire and tap into the low beam circuit. Then whenever the low beams are on the relay would be triggered. Then "if" you have a switch you can control it's on/off operation.
But those lens in those aren't really designed to be used with low beams as fog lights. You'd have to aim them down as to not blind other motorist at night.
That's why LR normally had em with the high beams to be used off road or out in the middle of nowhere.
Hmmm, maybe I'll just let it be...
WSMIKE
06-10-2017 07:34 AM
Frank4
11-21-2015 05:47 PM
dtm325
09-07-2013 04:43 PM
SpooledupRacing
07-26-2011 11:51 AM
wickham
01-08-2009 04:17 PM
Quick Reply: fog lights only come on when high beams are on
