Fouling plugs
Old Sep 17, 2009 | 10:50 AM
Hammers down's Avatar
6th Gear
Default Fouling plugs
I have a 1995 disco that will foul a set of plugs out in 5 min. A mechanic told me he was sure it was the mass air flow sensor, can i get a second opinion? What ever the problem it is running to rich to drive? any other ideas?
Old Sep 17, 2009 | 11:05 AM
unstable's Avatar
look at the plugs and see what they are getting fouled with. Is the rig throwing any codes?
Old Sep 17, 2009 | 11:37 AM
6th Gear
They are getting flooded with gas, can't check codes because this models code window is broken.
Old Sep 17, 2009 | 12:26 PM
Go get your fault codes from the LED under the passenger seat, no since guessing.
Old Sep 17, 2009 | 01:47 PM
6th Gear
led's are broken can't read it. Can the mass flow sensor cause the flooding is this a common problem? My mechanic says so.He says in 90 percent of the time this is the answer to the problem.
Old Sep 17, 2009 | 02:51 PM
Find a mechanic that can plug into your OBD1 system and get the codes read.
Old Sep 17, 2009 | 04:04 PM
Mike-he has said it twice now, he CANNOT read the trouble codes because the reader is broken.
If the MAF is sending a bad signal the ECU can overfuel the engine.
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
rylan906
Dec 4, 2012 05:59 PM
ngarover
Mar 8, 2011 04:46 PM
dkdirt63
Apr 17, 2005 11:05 PM
